"reactingParcelFoam" active gravity, high courant number
1 Attachment(s)
Dear all
I,m solving laminar flow and heat transfer of liquid water between two parallel plates. for the first case, lagrangian particles didn't injected. when the gravity is ( 0 0 0 ), the courant number is less than 0.12 but when the gravity is ( 0 -9.81 0 ) or ( 0 9.81 0 ) and with the same time step & BC, the courant number is higher than 200. the case file attached. 1- what is the problem for hight courant number?? 2- Is P boundary condition true?? 3- Is thermophysical properties true for liquid water with constant value ( no variate with temperature )?? Boundary and Initial conditions: Code:
/*--------------------------------*- C++ -*----------------------------------*\ Code:
/*--------------------------------*- C++ -*----------------------------------*\ the flow is laminar and turbulence is off: Code:
/*--------------------------------*- C++ -*----------------------------------*\ lgrangian particles didn't injected. reactions: Code:
species Code:
/*--------------------------------*- C++ -*----------------------------------*\ |
solution log for gravity off :
solution log for gravity on: Code:
I'm waiting for a response!
It's there any suggestion to solve this problem?? |
Have you solved your problem? I met the same problem as yours. why my Current number of parcels always 0 Regards, Ping |
Dear chpjz0391
No, I didn't solve it. because I neglect gravity. What's parcel courant number?? I didn't see that during my solution!!! I guess the cause of this problem is that "reactingparcelfoam" is a compressible solver that solve enthalpy for energy equation and when the gravity is activated, the unreal value of pressure cause the solver to diverge and have high courant number. |
reactingFoam
Hello all,
Have you been able to solve this issue? I am solving steady state compressible reactingFoam OpenFOAM 9 and I get really high courant number in the order of 5000-10000. I am absolutely stuck to this issue. Any help or hint is quite appreciated. Cheers, /Pooria |
Dear Pooria
I have forgotten whether I solved this issue or not. But finally I simplified the "reactingparcelfoam" and combined it with "pimplefoam" as my case was incompressible and did not have reaction, mass transfer, and .... So may be this problem was eliminated during this simplifying procedure. As I converted it to an incompressible solver. But if you really find this problem serious, you can report it to the "https://bugs.openfoam.org/rules.php". maybe this is a real bug. |
