March 24, 2016, 21:03 |
Running naca0012 problem
pan
Rep Power: 10 |
I have test the naca0012 case with dbnsTurbFoam in of-extend-3.1, but running some steps it appears a error of bounding h. The case is downloaded with the ex3.1 source code, I don't think it has some problems. Can someone help me? The attachment is the case file. I deleted mesh file from it, because it is too large. |
bounding error, extend-3.1, naca0012 |
problem of running parallel Fluent on linux cluster | ivanbuz | FLUENT | 15 | September 23, 2017 19:12 |
ANSYS Licensing Problem, Processes Running but Showing as Not Running | penguinman | ANSYS | 3 | September 27, 2016 13:30 |
Non- stop running for a time-dependent heat source problem | Asghari_M | OpenFOAM Programming & Development | 1 | May 11, 2015 05:13 |
[Other] Problem running after decomposition | paul.m.edwards | OpenFOAM Meshing & Mesh Conversion | 0 | January 14, 2015 12:55 |
paraFoam running problem | Aleksey_R | OpenFOAM | 2 | November 27, 2009 18:18 |
