nut, k, omega wall condition with k omega SST
Hi guys, i would like to understand if my assumptions are corrected. I have a mesh of an airfoil with y+ around wall <1. I want use k omega SST. This model considers flux turbulent fully developed, so i want to understand if i have to consider the flux like was in y+> 30 and then use wall functions?
hi guys, i have a mesh with y+<1 a i use k omega SST. How you valutate this BC on wall? K_wall=1e-12 omega_wall=1e+7 according this post:
You can use a very small, non-zero fixedvalue for k, omegawallfunction for omega and nutlowrewallfunction for nut. These are my preferred lowRe mesh wall BCs for the variables.
I've set nut to calculated. And I have a doubt if my fvschemes and fvsolution are correct:
Fv schemes ddtSchemes { default steadyState; } gradSchemes { default Gauss linear; } divSchemes { default none; div(phi,U) bounded Gauss linearUpwind grad(U); div(phi,k) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } wallDist { method meshWave; } Fv solution solvers { p { solver GAMG; tolerance 1e-06; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-08; relTol 0.1; } k { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.1; nSweeps 1; } omega { solver smoothSolver; smoother GaussSeidel; tolerance 1e-8; relTol 0.1; nSweeps 1; } } SIMPLE { nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; residualControl { p 1e-5; U 1e-5; k 1e-5; omega 1e-5; } } relaxationFactors { fields { p 0.3; } equations { U 0.3; k 0.3; omega 0.3; } } |
