How can I plot lagrangian particles leaving through a patch?
Like Tree3Likes
  • 1 Post By phandy
  • 2 Post By kou1shik
Old   October 28, 2015, 09:24
Question How can I plot lagrangian particles leaving through a patch?
Paul Handy
phandy is on a distinguished road
I'm trying to run a validation case similar to the MPPICFoam cyclone example, except for I have a patch at the bottom which the lagrangian particles can exit through. I would like to plot the size and number of particles exiting the bottom and top outlets respectively in order to find the fractional efficiency for each particle size.
My initial thoughts are to include a function block in the controlDict. I'm not sure what should go in there, and if I need to write my own library to do the counting, or if there is one already available in OpenFOAM.
Alternatively, is there a way to get paraview to plot the same data I seek?
Could anyone help me figure out how to accomplish this?
phandy is offline   Reply With Quote
Old   October 29, 2015, 12:20
Paul Handy
A bit of a reply to my own top post. I'm new enough to openfoam to not have known that each generated timestep has a uniform/lagrangian/kinematicCloud/kinematicCloudOutputProperties file. In patchInteractionModel.localInteraction, there exist nEscape ([parcel?] count) and massEscape, which are arrays that I presume map to my kinematicCloudProperties localInteractionCoeffs dictionary. This gives the total mass escaped and the count, from which I can make guesses to the particle size, though I was hoping for information for each parcel individually. Well, I suppose something is much better than nothing.
ShashiDeSilva likes this.
Old   March 30, 2016, 07:29
ksengupta
kou1shik is on a distinguished road
You can use cloudFunctions in constant/kinematicCloudProperties. Use like this.
cloudFunctions
patchPostProcessing1
type patchPostProcessing;
maxStoredParcels 1e07;
patches ( outlet );
Tobi and lxufeishi like this.
kou1shik is offline   Reply With Quote
Old   March 19, 2017, 15:49
Adam Katz
Adamkat is on a distinguished road
I added the cloudFunctions but now, how can I extract the information of particle hits?
Adamkat is offline   Reply With Quote
Old   March 27, 2017, 03:47
Adam Katz
Solved.
I wrote a script that extracts the data out of the patchPostProcessing files.
In hindsight, I could have used splashPanel (see: $FOAM_TUTORIALS/lagrangian/reactingParcelFilmFoam/splashPanel)
Old   August 24, 2018, 07:47
Default extract data out of patchPostProcessing
Arash Mahboubidoust
arashfluid is on a distinguished road
Send a message via Yahoo to arashfluid
Originally Posted by Adamkat View Post
Solved.
Dear Adamkat,
I also have a similar problem. I want to extract the data out of the patchPostProcessing files. Can you share your script?
Thanks
arashfluid is offline   Reply With Quote
Old   August 26, 2018, 07:19
Default Lost work
Adam Katz
Dear Arashfluid,
I'm sorry but I have forgotten about that work a long time ago.
I guess you'll have to do it on your own.
Sorry,
Adam
lagrangian, particle, size distribution, size functions
implementing new Lagrangian patch interaction Chrisi1984 OpenFOAM Programming & Development 0 May 31, 2014 04:49
[OpenFOAM] plot particles and animation in paraview phsieh2005 ParaView 1 July 26, 2013 05:35
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Plot particles w. correct size? Michael B CFX 1 August 8, 2006 02:36
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
