High pressure values at inlet and Loss of Mass flow at AMIs -- pimpleDymFoam
Old   April 14, 2016, 08:04
Angry High pressure values at inlet and Loss of Mass flow at AMIs -- pimpleDymFoam
Sravan Kumar
coolcrasher is on a distinguished road
Hi All,
I have been running centrifugal pump steady and transient case in last few months. Steady case works fine with simpleFoam solver. But I have problem with transient case with pimpleDyMFoam.
There is a mass flow loss when fluid is flowing through AMI patches. Also pressure boundary condition is fixed value and zero at outlet, but at inlet the pressure occured is too high. It is almost 5 times more. Inlet boundary condition used is zerogradient.
We have calculated the torque values as well. The torque values agree quite well. But pressure values is the only problem.
I am sharing the case folder for further refence:
https://www.dropbox.com/s/kixdj7oomm...a_135.zip?dl=0
However the case folder cannot be run since I have removed files from polymesh folder. Since I cannot share the geometry details or mesh of the pump. However one have look at the setting I have used.
Please help me out in correcting the errors. Please guide where I have gone wrong .
Also let me know in case you need any further information
coolcrasher is offline   Reply With Quote
Old   April 15, 2016, 04:41
Question
Sravan Kumar
Any help guys
Old   April 15, 2016, 11:26
Troy Snyder
tas38 is on a distinguished road
A more appropriate boundary condition (well-posed) for the inflow patch would be totalPressure for p and pressureInletOutltletVelocity for U if you are not specifying the velocity at the inflow.
tas38 is offline   Reply With Quote
Old   April 18, 2016, 02:51
Sravan Kumar
Hi Troy,
Thanks a lot for replying.
I have been using following boundary conditions.
For Vel:
Inlet -- fixed value of 5.5
Outlet -- zero gradient
For p:
Inlet -- zero gradient
Outlet -- fixed value of 0
Do u suggest me to use some fixed total pressure at inlet, instead of fixed inlet velocity ?
Please explain if I am not wrong
pimple, pimple transient, pimple. openfoam, pimpledymfoam
Pressure loss Velocity coupling CFXMUFFIN CFX 1 February 6, 2016 04:43
Calculate Density mumtaz ersan FloEFD, FloWorks & FloTHERM 1 September 17, 2015 04:26
Gate valve flow simulations... nikesh FloEFD, FloWorks & FloTHERM 5 January 28, 2014 01:31
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 13:45
Non-steady flow simplified for use in Vissim steamerandy Main CFD Forum 0 October 31, 2011 21:08
