March 13, 2019, 22:15 |
Run OF case on SCC?
LT
Rep Power: 15 |
Could anyone who accomplished OpenFOAM case on SCC (Super computation center) tell me how to give the command line if I try to run a case with 240 cores on 20 nodes?
I always get the message:Requested node configuration is not available. Thanks in advance! |
March 21, 2019, 01:14 |
LT
Rep Power: 15 |
No any clues?
After I started to compute one OF case, the procedure halts while the messages were given as follows: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.0 Exec : /WORK/app/OpenFOAM/OpenFOAM-4.0/platforms/linux64IccDPInt32Opt/bin/sprayFoam -parallel Date : Mar 21 2019 Time : 13:58:51 Host : "cn9720" PID : 2866 Case : /WORK/nsccgz_xliao_1/liutao/LMesh nProcs : 240 Slaves : 239 ( ...//something like 240 tasks are assigned ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 // The procedure stops right here PS: I can solve this case on one node. |
case, command line, openfoam, scc |
flotingObject case doesn't run when I change the dynamicMeshDict file. | saatt | OpenFOAM | 1 | July 9, 2017 08:26 |
How to run in transient the airFoil2D (simpleFoam) tutorial case? | csacska | OpenFOAM Running, Solving & CFD | 5 | June 19, 2017 08:45 |
damBreak case parallel run problem | behzad-cfd | OpenFOAM Running, Solving & CFD | 5 | August 2, 2015 17:18 |
Use XiFoam to run a laminar spherical flame case. | fcrl-zxr | OpenFOAM Running, Solving & CFD | 0 | June 8, 2015 11:11 |
DPMFoam case worked perfectly in the first run but crashes in every subsequent run!! | ansubru | OpenFOAM Running, Solving & CFD | 6 | March 17, 2014 04:27 |
