buoyantBoussinesqSimpleFoam for water impinging jet flow
hi
i have a question :p i have simulated a water impinging jet flow (incompressible case is water ) i chose buoyantBoussinesqSimpleFoam solver is correct or not if is not correct ??? and simplefoam+Temperature equation or buoyantBoussinesqSimpleFoam what is the best solver for this case ( impinging jet flow with water is the fluid) this is my question please help me and thank you for all amine :) |
Hello Amine,
the solver you have to choose is dependend on the phenomena's you have. If you have buoyancy driven flow, you need the buoyancy term that forces the fluid to flow. Hence you should use buoyant...Foam. SimpleFOAM + Temperature equation will not fulfill buoyancy if you not add the buoyancy force. Boussinesq Approximation is only fulfilled if you have only density change of 2-5% (for water), otherwise I would prefer to use the normal buoyant...Foam. FInally your question has to be answered by yourself. |
Hi Tobi,
kindly suggest a solver for a single-phase transient case involving, forced convections [inlet velocity of fluid: water] + gravity. I have tried using buoyantBoussinesqPimpleFoam by setting thermal expansion coefficient (beta) = 0. But I couldn't find the effect of gravity in the simulation. Kindly suggest how to proceed. Thanks |
Sorry to revive an old thread, but I was wondering if buoyantPimpleFoam can be used for supersonic flows? I see that HVAC is mentioned as a use case, which makes me a bit wary if it would work for supersonic flows. I am otherwise happy with sonicFoam, but I still need gravity after the flow has slowed down, specifically for the transport of particles in the flow.
It would be cool if buoyantPimpleFoam would work, otherwise I'll work on copying the gravity implementation over to sonicFoam, which hopefully will work. Thanks for any advice! Michael |
