Regarding rhoCentralFoam
Old   April 25, 2016, 07:31
Default Regarding rhoCentralFoam
Gopal Shinde
shinde.gopal is on a distinguished road
Hi Foamers,
I have a question. It is like this :
I am running the rhoCentralFoam for the flow simulation over OneraM6 wing.
The output of the solver is attached below
Starting time loop
forceCoeffs forces:
Not including porosity effects
Mean and max Courant Numbers = 1.747831e-05 0.03413952
Time = 1e-08
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoUx, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoUy, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoUz, Initial residual = 0, Final residual = 0, No Iterations 0
diagonal: Solving for rhoE, Initial residual = 0, Final residual = 0, No Iterations 0
ExecutionTime = 8.03 s ClockTime = 8 s
forceCoeffs forces output:
Cm = 9.136184e-05
Cd = 0.0003770677
Cl = 0.0007398541
Cl(f) = 0.0004612889
Cl(r) = 0.0002785652
Mean and max Courant Numbers = 1.747831e-05 0.03415259
Time = 2e-08
ExecutionTime = 11.02 s ClockTime = 11 s
The solver log shows initial residual and final residual as ZERO(as seen above).
Why is that so ? Plz help.
Gopal.
shinde.gopal is offline   Reply With Quote
compressible flow, residual, rhocentralfoam
How to apply a turbulence model to the rhoCentralFoam solver? arussell92 OpenFOAM Pre-Processing 18 July 25, 2022 04:26
Modify rhoCentralFoam: other equations of state fivos OpenFOAM Programming & Development 5 July 29, 2020 13:17
cavity using rhoCentralFoam Moslem OpenFOAM Verification & Validation 0 July 5, 2015 05:55
dynamic mesh refinement and rhoCentralFoam ChrisA OpenFOAM Running, Solving & CFD 1 March 21, 2013 08:00
rhoCentralFoam solver with Slip BCs fails in Parallel Only JLight OpenFOAM Running, Solving & CFD 2 October 11, 2012 21:08
