twoPhaseEulerFoam + fvOptions limitTemperature
Hi all,
is there a way to use limitTemperature with twoPhaseEulerFoam in OF301? my constant/fvoptions looks as following: Code:
valueLimitation Code:
Selecting finite volume options model type limitTemperature Thanks a lot Hannes |
I have a similar problem running twoPhaseEulerFoam coupled with a source in the fvOptions file. Have you found a solution to the problem? Regards, Sebastian |
Hey,
for OF 2.4.0 this definition worked for me: Code:
temperature_constraints Hope this helps. Best regards Katharina |
Hi Sebastian,
Have you found out a way to use the limitTemperature in twoPhaseEulerFoam in OF-3.0.1? I have the same problem. As Katharina said, the equivalent temperatureLimitsConstraint works perfectly for me in OF-2.3.1 Thanks Kumar |
Did you finally solve this issue? |
Hi Foamers,
Despite the old thread, I would like to mention an update. Thanks to OF developers there is a new option in the new version OpenFAOM-6 to define phase for which the limiTemperature is applied. This solution seems to work well. Code:
limitT Cheers, Robin |
