Data Writing Problem in Intel MPI
Like Tree1Likes
  • 1 Post By gtarang
Old   October 10, 2016, 14:51
Default Data Writing Problem in Intel MPI
xuegy is on a distinguished road
Hello all,
I compiled OpenFOAM 4.0 by Intel Parallel Studio 2017 in Ubuntu 16.04. After a few tweaks I managed to compile that
Everything is OK if I run it in single thread. However if I run it in parallel by Intel MPI it will crash after the first data is written. For example, if I choose to write every 0.1s, it will write 0.1s data and crash at exactly after 0.1s. Everytime I got similar messages from the terminal:
Fatal error in PMPI_Waitall: Other MPI error, error stack:
PMPI_Waitall(405)...............: MPI_Waitall(count=6, req_array=0x1d13f00, status_array=0x1) failed
MPIR_Waitall_impl(176)..........: fail failed
PMPIDI_CH3I_Progress(623).......: fail failed
pkt_RTS_handler(317)............: fail failed
do_cts(662).....................: fail failed
MPID_nem_lmt_dcp_start_recv(288): fail failed
dcp_recv(154)...................: Internal MPI error! cannot read from remote process
My MPI version: Intel(R) MPI Library for Linux* OS, Version 2017 Build 20160721
Anybody know how to solve it? Will it be a bug from the new version of Parallel Studio?
xuegy is offline   Reply With Quote
Old   May 6, 2018, 10:37
Tarang
gtarang is on a distinguished road
I am also facing the same problem in OF-5.0. Did you manage to solve it?
chaitanyaarige likes this.
gtarang is offline   Reply With Quote
Old   May 11, 2018, 03:19
Chaitanya
chaitanyaarige is on a distinguished road
I am also facing same error in Ubuntu 18.04 with CFX 19.0
chaitanyaarige is offline   Reply With Quote
AVL start problem :MPI issue gafoorcp AVL FIRE 1 June 21, 2022 02:27
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
Writing Expressions in Reports - using data from a previous time step yesaswi92 STAR-CCM+ 1 August 29, 2014 04:33
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
IFStream read float point data problem liu OpenFOAM Running, Solving & CFD 0 October 24, 2008 12:14
