Creating IB-Solver for turbulent channel flow
Old   May 3, 2016, 09:42
Default Creating IB-Solver for turbulent channel flow
K.H
urion is on a distinguished road
I expanded the icoIbFoam solver in foam extend 3.1 by the pressure-correction used in the solver channelFoam for a constant mass flow rate so i can use the new solver as DNS-solver for turbulent channel flow with IB. The problem is that the pressure- correction seems to be performed in the whole channel including the IB. This leads to a wrong mass flow. Therfore I was wondering if there is an easy way to change the code so that the pressure-correction is only performed in the cells outside the IB?
Link to used solver:
https://www.dropbox.com/sh/wfgf194ul...u3_FkDEAa?dl=0
urion is offline   Reply With Quote
Old   May 12, 2016, 09:21
Arjun
arjun will become famous soon enougharjun will become famous soon enough
In IB method pressure correction is usually solved in all domain including the marked regions.
Note that this is not hard and fast rule, I in my own code did solve only in flow regions due to problems in accuracy (Not openfoam code). It needs lots of change in code to do because matrix will now be smaller and different.
If you are facing accuracy issues mesh refinement is only friend you have.
arjun is offline   Reply With Quote
compressible flow calculation error using rhoSimpleFoam solver student4326 OpenFOAM Running, Solving & CFD 7 November 2, 2015 11:34
Using pimpleFoam to model pulsatile flow in a micro channel isaacp OpenFOAM Running, Solving & CFD 0 January 30, 2012 00:03
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Wrong Pressure countors for channel flow driven by mass flow rate or press gradient ash-khan FLUENT 0 June 21, 2009 10:02
Open Channel Flow using InterFoam type solver sxhdhi OpenFOAM Running, Solving & CFD 3 May 5, 2009 21:58
