qjh888 |
May 19, 2016 10:09 |
How to set the k and epsilon boundary condition?
Hi foamers,
I'm fresh man in OpenFOAM. Now I'm doing a simulation with quite simple geometry use the rhoSimpleFoam solver.
When i turn off the turbulence model, the solver runs normally.
But when I turn on the turbulence model, some problems came up:
--> when I use the
turbulentMixingLengthDissipationRateInlet;
as my epsilon inlet condition type, here is the error message:
| \\ / F ield | foam-extend: Open Source CFD |
| \\ / O peration | Version: 3.0 |
| \\ / A nd | Web: http://www.extend-project.de |
| \\/ M anipulation | |
Build : 3.0-7a7445ead09d
Exec : rhoSimpleFoam
Date : May 19 2016
Time : 23:07:31
Host : Janry
PID : 15312
CtrlDict : /home/uqjqi/foam/foam-extend-3.0/etc/controlDict
Case : /home/uqjqi/Desktop/Turbine_Meshing/22_Apr_2016_tutorial_mesh/Same_06
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0
Initializing the GGI interpolator between master/shadow patches: OF_outlet_00/OF_inlet_10
Initializing the GGI interpolator between master/shadow patches: OF_wall_00/OF_wall_01
Initializing the GGI interpolator between master/shadow patches: OF_wall_10/OF_wall_11
Reading thermophysical properties
Selecting thermodynamics package hPsiThermo<pureMixture<sutherlandTransport<specieThermo<hConstThermo<perfectGas>>>>>
Reading field U
Creating turbulence model
Selecting RAS turbulence model kEpsilon
Starting time loop
Time = 5e-05
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 3.2618e-08, No Iterations 12
smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 3.25243e-08, No Iterations 12
smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 3.56396e-08, No Iterations 11
DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 0.0943355, No Iterations 6
DILUPCG: Solving for p, Initial residual = 1, Final residual = 8.86246e-08, No Iterations 96
time step continuity errors : sum local = 1.27578e-06, global = 1.92449e-07, cumulative = 1.92449e-07
rho max/min : 1.73793 1.11227
--> FOAM FATAL ERROR:
gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type turbulentMixingLengthDissipationRateInlet)
on patch OF_inlet_00 of field epsilon in file "/home/uqjqi/Desktop/Turbine_Meshing/22_Apr_2016_tutorial_mesh/Same_06/0/epsilon"
You are probably trying to solve for a field with a generic boundary condition.
From function genericFvPatchField<Type>::gradientInternalCoeffs() const
in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 811.
FOAM exiting
I am really no idea about it.
So who can help me out ?
Thanks a lot in advance!
