-   OpenFOAM Running, Solving & CFD (https://www.cfd-online.com/Forums/openfoam-solving/)
-   -   Free Convection using chtMultiRegionFoam - wrong results (https://www.cfd-online.com/Forums/openfoam-solving/172025-free-convection-using-chtmultiregionfoam-wrong-results.html)
peterhess May 23, 2016 01:25
Hello everybody!
During my training process to use openFoam I work now on free convection simulation using chtMultiRegionFoam...
For this target I built a mesh from two regions a solid region and a fluid one.
The solid region contains a heat source programed in fvOptions file in the solid region constant dictionary.
The fluid region is a prefect gas air assumed...
No radiation (turned of). And no turbulence (laminar), to make the calculation easier...
The mesh has been generated using Ansys Mesher and have very high quality.
- Import made using: fluent3DMeshToFoam Test2.msh!
- The one region imported is splited to two regions using: splitMeshRegions -cellZones -overwrite
- The simulation is splited on two cores using: decomposePar -allRegions
The geometry contains 6 sides, three of them are symmetrical defined.
The upper, lower and back sides are constant temperature 300 K
The contact between solid and fluid is correctly defined (I suppose).
The gravity is defined in Z direction.
To run the simulation simply fire the Allrun file included. The running is in parallel on two cores.
- you can also run using: mpirun -np 2 chtMultiRegionFoam -parallel
Just the last result has been shown here to reduce the size of uploaded file!
Problem:
At the surrounding walls (upper, lower and back sides), the density of air is about 0.75 and should be theoretically 1.1881
I have no idea why is that happens.
Any idea is welcome
Regards
Peter
PS: changing to chtMultiRegionSimpleFoam brought also wrong results
peterhess May 23, 2016 01:34
sorry! the file is too big for CFDOnline. I will manage it and repost...
