-   OpenFOAM Running, Solving & CFD (https://www.cfd-online.com/Forums/openfoam-solving/)
-   -   rhoSimpleFoam does not accept my kOmegaSST settings? (https://www.cfd-online.com/Forums/openfoam-solving/172098-rhosimplefoam-does-not-accept-my-komegasst-settings.html)
NablaDyn May 24, 2016 05:22
Hello all,
I have recently encountered a problem when I tried to use rhoSimpleFoam in conjunction with the kOmegaSST turbulence model. I tried both options interdependently (they worked just fine) but when I put them together OpenFOAM crashes and gives the following output (right at the point where OF normally would output the kOmegaCoeffs):
| \\      /  F ield        | OpenFOAM: The Open Source CFD Toolbox          |
|  \\    /  O peration    | Version:  3.0.1                                |
|  \\  /    A nd          | Web:      www.OpenFOAM.org                      |
|    \\/    M anipulation  |                                                |
Build  : 3.0.1-119cac7e8750
Exec  : rhoSimpleFoam
Date  : May 24 2016
Time  : 10:54:35
Host  : "ihgg-ubuntu"
PID    : 6155
Case  : /home/lichtmes/Data/cases/4000/stationary_very_coarse_1bar_voxelmesh
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: no convergence criteria found. Calculations will run for 30000 steps.
Reading thermophysical properties
Selecting thermodynamics package
    type            hePsiThermo;
    mixture        pureMixture;
    transport      sutherland;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleEnthalpy;
Reading field U
Creating turbulence model
Selecting RAS turbulence model kOmegaSST
Selecting patchDistMethod meshWave
bounding k, min: 0 max: 1e-50 average: 0
bounding omega, min: 0 max: 1e+10 average: 0
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#5  Foam::RASModels::kOmegaSST<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::F2() const at ??:?
#6  Foam::RASModels::kOmegaSST<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::F23() const at ??:?
#7  Foam::RASModels::kOmegaSST<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correctNut(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#8  Foam::RASModels::kOmegaSST<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correctNut() at ??:?
#9  Foam::RASModels::kOmegaSST<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::kOmegaSST(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&, Foam::word const&) at ??:?
#10  Foam::RASModel<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::adddictionaryConstructorToTable<Foam::RASModels::kOmegaSST<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > > >::New(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) at ??:?
#11  Foam::RASModel<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::New(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::fluidThermo const&, Foam::word const&) at ??:?
#12  ? at ??:?
#13  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#14  ? at ??:?
Floating point exception (core dumped)
Im not so much into these sorts of error messages but I guess it's caused by ill-defined boundary conditions or model dictionaries. I've been trying to fix it for quite a few hours but I don't seem to have any success.
Could someone please give me a hint where to look at or what to check?
Thanks in advance!
Regards
NablaDyn May 24, 2016 08:27
I solved my problem!:)
It was all triggered by a bad pressure initialization.
I initialized the boundary patches according to the atmospheric pressure p_a=101325 Pa and total pressure p_t=p_a+x but forgot to assign a non-zero value to the internal field. After setting it to p_a everything seems just fine.
Anyway, thanks to all the readers.
Regards
