porousSimpleFoam - keyword wallDist undefined
Hi everyone,
I am working on a model with a porous net, which should be simulated using the porousSimpleFoam solver. When trying to run it, simulation stops shortly after having started and displays following error message: Code:
Selecting incompressible transport model Newtonian Thanks in advance |
This needs to be added to the end of fvSchemes. Code:
wallDist Code:
grep -r wallDist $FOAM_TUTORIALS Regards, Tom |
It works, thanks a lot!
I was adapting a case made with v2.3.0 to work in v3.0.1, that's probably why this little detail slipped... |
why this keyword now is necessary? Thanks |
I am not 100% sure, but I believe the change was due to the method not being hardcoded anymore in the most recent versions of OpenFOAM. These kind of changes happen between major version changes and are usually described in release notes.
Create time
Create mesh for time = 0 PIMPLE: No convergence criteria found PIMPLE: Operating solver in PISO mode Reading field p_rgh Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model kOmegaSST --> FOAM FATAL IO ERROR: keyword wallDist is undefined in dictionary "/home/negin/Desktop/article/article/system/fvSchemes" file: /home/negin/Desktop/article/article/system/fvSchemes from line 20 to line 55. From function const Foam::dictionary& Foam::dictionary::subDict(const Foam::word&) const in file db/dictionary/dictionary.C at line 701. FOAM exiting what does walldist mean and the best value for walldist is what? |
