mapFields produces '-' entry in BC files. Unable to run simulation!
Hello everyone,
I want to initialize a case with mapFields but when I try to run the mapped case or decompose it for parallel run, the following message occurs : Code:
--> FOAM FATAL IO ERROR: I used this command to map a consistent case (same geometries): Code:
mapFields -consistent <source case> Cheers! Charles |
