chtMultiRegionSimpleFoam. BC. Inlet, Outlet Flow |
June 8, 2016, 11:02 |
Paola
Rep Power: 9 |
Hi there!
I am new using OpenFOAM and would like to share a few questions with you. I am currently developing a steady state thermal model (chtMultiRegionSimpleFoam) that consists of a building with two inlets windows at the side and one outlet window at the top. Inside it, I have placed a heat source. I wanna evaluate natural convection occurring inside the building, as well as the temperatures and velocities around the model. I am not sure about which BC I should use for the inlet and outlet windows. Has anyone done something similar? Thank you! Paola. |
June 9, 2016, 07:17 |
Pedro
Rep Power: 11 |
First of all, may I ask why use the CHTMultiRegion? it seems liek your problem considers only flow.
Anyway. I'm dealing with a similar problem (flow inside an annulus) and so far the only boundary conditions that work are: Code:
U: Outlet { type zeroGradient; } Inlet { type zeroGradient; } P_rgh: Inlet { type fixedValue; value uniform 101325; } Outlet { type zeroGradient; } T: Inlet { type fixedValue; value uniform 293.7;} Outlet { type zeroGradient; } Also, check this thread ( http://www.cfd-online.com/Forums/ope...-behavior.html ) to see how i changed the initial solution of the problem. It also works in buoyantSimpleFoam and CHTMultiRegionSimpleFoam with some minor changes. IT greatly increases convergence speed. |
June 13, 2016, 09:28 |
Paola
Rep Power: 9 |
Hi Pedro! thank you so much for your reply.
Actually my problem has a few solid regions (building, heater, floor) and one fluid region (air), that's why I'm using chtMultiRegionSimpleFoam. I ran my case with the boundary conditions you said but it didn't work (maximum number of iterations exceeded). I've tried a bunch of different BC and sometimes I manage to obtain good temperature values, but the wallHeatFluxes at the BC doesn't have much sense (the flux between interfaces is correct, but at the boundaries it's not working well since the energy balance has no sense at all, do you know why is that?) Paola |
June 13, 2016, 11:31 |
Error after 10 iterations transient case
Paola
Rep Power: 9 |
Hello!
I'd like to run a transient case where the temperature of the BC varies with time. The geometry of my case is the same as before, so I'm using chtMultiRegionFoam since I have solid and fluid regions, but after 10 iterations, I get this error: Code:
Time = 1 Solving for fluid region Aire diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Ux, Initial residual = 0.5670344, Final residual = 2.619258e-08, No Iterations 47 DILUPBiCG: Solving for Uy, Initial residual = 0.4106254, Final residual = 7.722867e-08, No Iterations 48 DILUPBiCG: Solving for Uz, Initial residual = 0.5202844, Final residual = 3.483137e-08, No Iterations 48 DILUPBiCG: Solving for h, Initial residual = 0.1934812, Final residual = 2.74785e-08, No Iterations 46 Min/max T:284.3531 390.5775 GAMG: Solving for p_rgh, Initial residual = 0.8751491, Final residual = 0.00850716, No Iterations 8 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors (Aire): sum local = 0.04660027, global = 0.0085699, cumulative = 0.007883122 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam222/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam222/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Uninterpreted: #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam222/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam222/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam222/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) in "/opt/openfoam222/platforms/linuxGccDPOpt/lib/libfiniteVolume.so" #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam222/platforms/linuxGccDPOpt/bin/chtMultiRegionFoam" #8 in "/opt/openfoam222/platforms/linuxGccDPOpt/bin/chtMultiRegionFoam" #9 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #10 in "/opt/openfoam222/platforms/linuxGccDPOpt/bin/chtMultiRegionFoam" Excepción de coma flotante (`core' generado) Paola |
July 7, 2016, 04:03 |
Paola
Rep Power: 9 |
Hi everybody!
After 26 different cases, here is my conclusion: you can obtain a very stable configuration by setting the inlet velocity and the pressure at the outlet, so I'm gonna write the boundary conditions for the fluid region that I used. Velocity: inlet- fixedValue outlet- inletOutlet Temperature: inlet- fixedValue outlet- inletOutlet Pressure: inlet - zeroGradient outlet - fixedValue Hope it's useful for you! Last edited by pvs9; July 7, 2016 at 05:51. |
boundary, chtmultiregionsimplefoam, flow, inlet, outlet |
Incompressible flow velocity: outlet faster than inlet | Xuekun | Main CFD Forum | 13 | October 30, 2015 14:52 |
Mass flow inlet and pressure outlet issue | nikhil | FLUENT | 5 | December 11, 2013 12:30 |
Species mass flow inlet | lorenz | FLUENT | 3 | March 15, 2012 07:26 |
Net mass flow inlet vs outlet | Nigui28 | FLUENT | 1 | August 12, 2011 10:09 |
VOF Outlet boundary condition in cfd - ace | JM | Main CFD Forum | 0 | December 15, 2006 08:07 |
