Boundary conditions for shear thinning material
Old   June 16, 2016, 06:57
Default Boundary conditions for shear thinning material
open is on a distinguished road
Hi all,
Working on a problem with non-Newtonian shear thinning materials. It is expected (cf. experiments) that the outlet velocity is substantially increased (order of 20-50 %) in response to interaction with high shear rate objects. By this I mean oscillating wall or similar.
However in all the cases I've tried so far (2D, 3D, oscillating walls, oscillating velocity BC; pimpleDyMFoam, nonNewtonianIcoFoam) the outlet velocity tends to equalize with the inlet velocity (1 m/s). I'm not anticipating mesh problems since checkMesh passes and the geometry is a rectangular channel. What are the appropriate boundary conditions to permit shear thinning velocity increases?
Example:
U
    wInlet
        type            pressureInletVelocity;
        value           uniform ( 0 0 0 );
    wOutlet
        type            pressureInletOutletVelocity;
    wWall
        type            oscillatingFixedValue;
        refValue    uniform ( 0 0 -1 );
        offset          ( 0 0 1 );
        frequency    40;
        amplitude    0.156078;
P
wOutlet
        type            fixedValue;
        value           uniform 0;
    wInlet
        type            fixedValue;
        value           uniform 9810; // rho*g
    wWall
        type            zeroGradient;
transportModel  powerLaw;
powerLawCoeffs
    nuMin        nuMin [ 0 2 -1 0 0 0 0 ] 1e-4;
    nuMax        nuMax [ 0 2 -1 0 0 0 0 ] 4;
    k               k [ 0 2 -1 0 0 0 0 ] 0.04; // k/rho k=40
    n               n [ 0 0 0 0 0 0 0 ] 0.3;
   rho rho [1 -3 0 0 0 0 0 ] 1000.0;
dt~1e-8 (variable)
open is offline   Reply With Quote
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Low torque values on Screw Turbine Shaun Waters CFX 34 July 23, 2015 08:16
error message cuteapathy CFX 14 March 20, 2012 06:45
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
