Interface instabilities on liquid jet in interFoam
Like Tree1Likes
  • 1 Post By stuntmanmike
Old   June 16, 2016, 09:06
Default Interface instabilities on liquid jet in interFoam
stuntmanmike is on a distinguished road
I am currently investigating the primary breakup of a liquid jet in a pressurized nitrogen atmosphere as preliminary investigations for my master thesis.
I am doing LES with interFoam in a simple cylindrical domain with an inlet diameter d. The domain extends over 15d in axial direction and 5d in radial direction (uniformly refined hexahedral with approx 10M cells).
physical parameters are:
d = 90e-6 m
v_liquid = 125 m/s
sigma = 0.0186 kg/s^2
rho_liquid / rho_gas = 24,19
Re = 16071
We = 51864
CFL = 0.1
The simulation and the breakup seem fine somehow (the mesh still is a bit too coarse to capture small droplets) but there are developing ripple-like instabilities on the mushroom shaped top of the jet which are clearly unphysical. I assumed they are caused by the mesh quality of the o-grid but after improving the mesh quality they still appear and I am running out of ideas how to fix this. I also read through some other threads and came accross the problem of parasitic currents caused by the CSF implementation. However they seems to be more a problem of surface tension dominated flows which is not the case here. Could this still be the problem?
I attached pics to show the problem. Does someone have an idea how to fix this??
Many thanks in advance
Simon
tonnykz likes this.
stuntmanmike is offline   Reply With Quote
Old   June 16, 2016, 09:49
akidess's Avatar
Anton Kidess
Case setup? What are you plotting?
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   June 16, 2016, 10:19
The domain dimensions are as described. The liquid is entering the domain from a circular inlet in the center of the bottom plane of the cylinder and is flowing upwards. The plot is showing the interface alpha = 0.5. The mesh shows the bottom plane of the clinder (where the liquid enters in the center).
Old   June 16, 2016, 10:54
akidess's Avatar
Anton Kidess
Solver and discretization settings not relevant?
Old   June 16, 2016, 11:06
Oh sorry.
The fvSchemes looks like that:
|  \\    /   O peration     | Version:  2.3.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    default         pointCellsLeastSquares; //Gauss linear;
divSchemes
    default             none;
    div(rhoPhi,U)      Gauss linearUpwind grad(U);
    div(phi,alpha)      Gauss vanLeer;
    div(phirb,alpha)    Gauss vanLeer;
    "div\(phi,(k|omega)\)"      Gauss upwind;
    div((muEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p_rgh;
    pcorr;
    alpha.water;
I changed grad scheme from Gauss linear to pointCellsLeastSquares cause I read it gives more acurate results, however it didn't fix the problem.
The fvSolutions looks like that:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    "alpha.water.*"
        nAlphaCorr      2;
        nAlphaSubCycles 1;
        cAlpha          1;
        MULESCorr       yes;
        nLimiterIter    25;
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-10;
        relTol          0;
    pcorr
        solver          PCG;
        preconditioner
            preconditioner  GAMG;
            tolerance       1e-5;
            relTol          0;
            smoother        GaussSeidel;
            nPreSweeps      0;
            nPostSweeps     2;
            nFinestSweeps   2;
            cacheAgglomeration true;
            nCellsInCoarsestLevel 10;
            agglomerator    faceAreaPair;
            mergeLevels     1;
        tolerance       1e-5;
        relTol          0;
        maxIter         100;
    p_rgh
        solver           GAMG;
        tolerance        5e-9;
        relTol           0.01;
        nPreSweeps       0;
        nPostSweeps      2;
        mergeLevels      1;
        maxIter          100;
    p_rghFinal
        $p_rgh;
        tolerance       5e-9;
        relTol          0;
    "(U|k|omega).*"
        nSweeps         1;
        tolerance       1e-6;
        relTol          0.1;
PIMPLE
        momentumPredictor no;
        nCorrectors     2;
        nNonOrthogonalCorrectors 0;
    turbOnFinalIterOnly false;
    //nOuterCorrectors    25;
relaxationFactors
    fields
    equations
        ".*" 1;
I hope these are all relevant information.
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
how to use UDF to obtain the thred of the interface between the liquid and the wall? hellowqy Fluent UDF and Scheme Programming 8 December 17, 2015 10:03
Displying interface of liquid water using VoF model pchoopanya FLUENT 2 March 15, 2013 16:42
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
