June 21, 2016, 21:25 |
mdFoam, FOAM FATAL IO ERROR
I want to run the "nanoNozzle" of mdFOAM in the "tutorials" of OpenFOAM. So, I copied the "nanoNozzle" file in the "run" folder and used the "blockMesh" command to create the geometry and mesh. It performed this without any error. However, as I used "mdFoam" command to solve it, it encountered with an error with the following details:
--> FOAM FATAL IO ERROR: cannot open file fille: /home/nikoot/OpenFOAM/nikoot-3.0.1/run/nanoNozzle/constant/idList at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 87. FOAM exiting How can I solve this persistent error? I really appreciate your help. Thank you in advance for your consideration and reading my message. Nader Nekoubin |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 09:40 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x | Saxwax | OpenFOAM Installation | 25 | November 29, 2013 05:34 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
