mdFoam, FOAM FATAL IO ERROR
I want to run the "nanoNozzle" of mdFOAM in the "tutorials" of OpenFOAM. So, I copied the "nanoNozzle" file in the "run" folder and used the "blockMesh" command to create the geometry and mesh. It performed this without any error. However, as I used "mdFoam" command to solve it, it encountered with an error with the following details:
--> FOAM FATAL IO ERROR: cannot open file fille: /home/nikoot/OpenFOAM/nikoot-3.0.1/run/nanoNozzle/constant/idList at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 87. FOAM exiting How can I solve this persistent error? I really appreciate your help. Thank you in advance for your consideration and reading my message. Nader Nekoubin |
