compressible flow, rhoSimpleFoam, boundary conditions |
June 26, 2016, 14:27 |
Lefteris
Rep Power: 15 |
Hi all.
I'm trying to solve a compressible flow with rhoSimpleFoam but I can't get it to converge. I believe it is a boundary conditions issue as simpleFoam does run ok on the same mesh (for lower velocity, incompressible cases). The topology consists of one inflow and two outflows (please see the attached image to get the idea). My problem is that I cannot find the right set of boundary conditions for the patch in coloured in red on the image. All variables are known at the inlet. I'm not sure if this makes any difference but that's the thermophysical properties I use: type hePsiThermo; mixture pureMixture; transport sutherland; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; Can someone suggest what set of boundary conditions could work with rhoSimpleFoam? Thanks a lot! ps I use OF 3.0.1 but I could also use OF 2.3.1.
Lefteris |
boundary condition, compressible flow, rhosimplefoam |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Boundary conditions at inlet/outlet of a pipe with compressible flow | nicola_78 | Main CFD Forum | 10 | November 19, 2015 11:20 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
