Case decomposition of a scene with a small object
Old   June 26, 2016, 10:59
Default Case decomposition of a scene with a small object
Vladislav Galas
gallon is on a distinguished road
Hello CFD, hope this is the right forum to ask the question.
The goal is to place an stl model and refine the mesh.
Everything goes fine in serial but since I want to refine up to 5-6 levels it takes too long.
So here's my script:
blockMesh
decomposePar [-force]
At this decomposePar knows nothing about WALL10 (the surface read from .stl by sHM).
OK, then I run
surfaceFeautureExtract
mpirun -np 2 snappyHexMesh -overwrite -parallel
mpirun -np 2 sonicFoam -parallel
The surface is read and refined in parallel OK. If a given processors's decomposed domain does not contain a part of the surface, it is still mentioned in processorX/constant/polyMesh/boundary as an empty boundary:
[v.galas@node1 tmp]$ cat processor0/constant/polyMesh/boundary
|  \\    /   O peration     | Version:  v3.0.1                                |
FoamFile
    version     2.0;
    format      ascii;
    class       polyBoundaryMesh;
    location    "constant/polyMesh";
    object      boundary;
4
    OUTL2
        type            patch;
        nFaces          22816;
        startFace       418376;
    INLE1
        type            patch;
        nFaces          0;
        startFace       441192;
    WALL10
        type            wall;
        inGroups        1(wall);
        nFaces          0;
        startFace       441192;
    procBoundary0to1
        type            processor;
        inGroups        1(processor);
        nFaces          1360;
        startFace       441192;
        matchTolerance  0.0001;
        transform       unknown;
        myProcNo        0;
        neighbProcNo    1;
But now the solver run at the processors without WALL10 cannot find the BC for it.
I have tried mapFields and redistributePar but to no avail.
p.s. sHM (serial) -> decomposePar -> sonicFoam (parallel) works ok.
Any ideas?
gallon is offline   Reply With Quote
Odd lagrangian particle behavior at small size phandy OpenFOAM Running, Solving & CFD 2 November 11, 2017 18:07
Simple channel case using cyclicAMI will not converge cbcoutinho OpenFOAM Running, Solving & CFD 3 August 4, 2015 12:28
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 16:31
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
