Taataa |
June 28, 2016 04:04 |
Negative values for minimum alphas
Hi all,
I am using compressibleInterFoam solver to model an internal flow, mixture of water and air. The problem is that I keep getting negative values for minimum alpha of air and of water. I tried implementing limiters such as valLeer01 and MUSCL01 methods for div(phi,alpha) and div(phirb,alpha) but no success. I looked through the forum and found a similar post but it couldn't solve my problem. Here are the numerical schemes that I am using:
ddtSchemes
default Euler;
gradSchemes
default cellLimited Gauss linear 0.5;
grad(U) cellLimited Gauss linear 0.5;
divSchemes
div(phi,alpha) Gauss MUSCL01;
div(phirb,alpha) Gauss MUSCL01;
div(rhoPhi,U) Gauss vanLeerV;
div(phi,p) Gauss upwind;
div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
"div\(phi,(k|thermo:rho.water|thermo:rho.air|)\)" Gauss linearUpwind default;
"div\(rhoPhi,(T|K|epsilon|k)\)" Gauss linearUpwind default;
laplacianSchemes
default Gauss linear limited 1.0;
interpolationSchemes
default linear;
snGradSchemes
default limited 1.0;
and here are the solver options that I am using for alphas:
"alpha.*"
nAlphaCorr 1;
nAlphaSubCycles 2;
cAlpha 1;
icAlpha 0.25;
MULESCorr yes;
nLimiterIter 8;
alphaApplyPrevCorr true;
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-6;
relTol 1e-3;
Any suggestion is appreciated.
