Fluctuating velocity magnitude
Old   January 19, 2020, 07:48
Default Fluctuating velocity magnitude
ras27 is on a distinguished road
Hello everyone,
when running the simulation, the velocity magnitude fluctuates quite significantly between the iterations/time steps - e.g. iteration x: v. magnitude=0.7; iteration x+1: v. magnitude=1.8; iteration x+2: v. magnitude=0.7 …
The inlet velocity BC uses a ramp with steadily rising velocity...shouldn't the velocity magnitudes of the time steps also rise in this manner, or is this fluctuating velocity magn. behaviour rather normal for water (surely turbulent from a certain inlet velocity) flow?
Setup=pisoFoam, komegaSST…
Regards,
ras27
ras27 is offline   Reply With Quote
Old   January 19, 2020, 08:55
PS: The solution seems to be to increase the # of non-orthogonal correctors in this case
Velocity Magnitude for Steady state RANS Manu4CFD FLUENT 4 June 15, 2019 00:11
kindly help me .. i have and error at line number 147.. m zubair Fluent UDF and Scheme Programming 0 February 10, 2019 11:25
UDF comilation error. urgent help please m zubair Fluent UDF and Scheme Programming 4 February 10, 2019 11:19
How to improve Velocity magnitude ravi FLUENT 0 June 23, 2003 13:17
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
