rhoSimpleFoam Hot Gas in Small Pipe Not reaching steady state
Old   August 29, 2017, 12:51
Default rhoSimpleFoam Hot Gas in Small Pipe Not reaching steady state
Annonymouse
ben_ is on a distinguished road
Hello all,
I am running a compressible flow with heat transfer in a small pipe of diameter 10mm. The simulation does not reach steady state, and it also does not seem to change in time steps. I am concerned with the results because they all have very small gradients (see attached) and according to my hand-calcs, the outlet temperature is currently ~200K colder than it should be. Has anyone had this problem, where the constant temperature wall condition does not seem to affect the fluid flow?
For this type of simulation, the Co number forces dt to be very small ~1e-7s. This makes the simulation computationally difficult. Does anyone know how many seconds we expect a pipe like this to converge behavior? It is possible that my two questions are related by the timescale of heat transfer between the wall and the fluid.
Thank you in advance, your help is greatly appreciated as I am currently stuck for how to proceed.
I used the following conditions (fixed):
0, T
fluid_temp 600.0;
wall_temp 1374;
internalField uniform $fluid_temp; // My Sim
boundaryField
outlet_pipe
type zeroGradient;
bend
type fixedValue;
value uniform $wall_temp;
inlet_pipe
type fixedValue;
inlet
type fixedValue;
value uniform $fluid_temp; // My Sim
outlet
type inletOutlet;
value uniform 500; // My Sim
inletValue uniform $fluid_temp; // My Sim
0, p
inlet_pressure 15600000;
outlet_pressure 15000000;
internalField uniform $inlet_pressure; // My Settin
boundaryField
outlet_pipe
type zeroGradient;
bend
type zeroGradient;
inlet_pipe
type zeroGradient;
inlet
type fixedValue;
value uniform $inlet_pressure;
outlet
type inletOutlet; // MySim
inletValue uniform $inlet_pressure;
value uniform $outlet_pressure;
0, U
dimensions [0 1 -1 0 0 0 0];
mdot 0.804;
rho_guess 11.2;
ux_inlet_guess 918.3;
internalField uniform (0 0 0); // My Sim
boundaryField
bend
type noSlip;
inlet_pipe
type noSlip;
outlet_pipe
type noSlip;
inlet
type flowRateInletVelocity;
massFlowRate constant $mdot; // My Sim
rhoInlet $rho_guess;
outlet
type inletOutlet;
value uniform (0 $ux_inlet_guess 0); // My Sim
inletValue uniform ($ux_inlet_guess 0 0); // My Sim
ben_ is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
Hot gas bubble collapse in cool water William Palm FLUENT 1 April 20, 2005 10:53
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
gas expansion in pipe crack propagation Marco Evangelos Biancolini Main CFD Forum 2 October 4, 2000 10:41
