July 6, 2016, 13:53 |
attempt to read beyond EOF
Bobby
Rep Power: 15 |
Dear Fellows
I have a rectangular -shaped grid which its bottom should be a wall with discontinuous distribution of one of scalars. In other words, for defining Ue (scalar) on the bottom wall of my grid I want to use a discontinuous distribution as follows: At the bottom wall I have: y=0 Code:
-3<x<-2 Ue=0 -2<x<-0.5 Ue=1 -0.5<x<0.5 Ue=0 0.5<x<2 Ue=-1 2<x<3 Ue=0 Code:
downWall { type uniformFixedValue; uniformValue csvFile; csvFileCoeffs { fileName "$FOAM_CASE/myDataFile" outOfBounds clamp; hasHeaderLine true; refColumn 0; componentColumns 1; // vector example } } Code:
downWall { type wall; nFaces 95; startFace 3780; } Code:
Reading field Electric Potential Ue --> FOAM FATAL IO ERROR: attempt to read beyond EOF file: /home/babak/interFoamEHD_EHDMR_Cases_Public/Cases/validation_v2/planarElectrostaticProblem/0/Ue::boundaryField::downWall::csvFileCoeffs::componentColumns at line 39. From function ITstream::read(token&) in file db/IOstreams/Tstreams/ITstream.C at line 83. FOAM exiting |
[Gmsh] No cells read from file ".msh" | hwsv07 | OpenFOAM Meshing & Mesh Conversion | 5 | August 13, 2018 15:42 |
Problem running in parralel | Val | OpenFOAM Running, Solving & CFD | 1 | June 12, 2014 02:47 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 | UDS_rambler | FLUENT | 2 | November 22, 2011 09:46 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 17:51 |
