Incompatible dimensions for operation
I am getting an error as below. Can someone help me solving it?
Courant Number mean: 0 max: 0 --> FOAM FATAL ERROR: incompatible dimensions for operation [U[0 1 -2 0 0 0 0] ] == [-grad(p)[1 -2 -2 0 0 0 0] ] From function checkMethod(const fvMatrix<Type>&, const GeometricField<Type, fvPatchField, volMesh>&) in file /home/opencfd/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/fvMatrix.C at line 1356. FOAM aborting #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 void Foam::checkMethod<Foam::Vector<double> >(Foam::fvMatrix<Foam::Vector<double> > const&, Foam::DimensionedField<Foam::Vector<double>, Foam::volMesh> const&, char const*) at ??:? #3 at ??:? #4 at ??:? #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #6 at ??:? Aborted (core dumped) Thank you. |
You have wrong pressure dimensions. Guess, the solver is incompressible, so equations are divided by density. |
after changing dimensions of pressure
Create time
Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RASModel Selecting RAS turbulence model kEpsilon bounding k, min: 0 max: 0.0937 average: 0.0937 bounding epsilon, min: 0 max: 2.39 average: 2.39 kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; sigmaEps 1.3; } Starting time loop Time = 0.0025 Courant Number mean: 0 max: 0 ^[[BsmoothSolver: Solving for Ux, Initial residual = 1, Final residual = 9.33146, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0823896, No Iterations 1000 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 2.16149, No Iterations 1000 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #8 Foam::fvMatrix<double>::solve() at ??:? #9 at ??:? #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #11 at ??:? Floating point exception (core dumped) |
there was mistake in the velocity. corrected it. but then, this.
Courant Number mean: 0.000837853 max: 0.179413 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 4.77775e-06, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 4.82191e-06, No Iterations 1 smoothSolver: Solving for Uz, Initial residual = 1, Final residual = 2.96083e-12, No Iterations 1 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #8 Foam::fvMatrix<double>::solve() at ??:? #9 at ??:? #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #11 at ??:? Floating point exception (core dumped) |
Since you keep your case in secret (even solver you are using could only be guessed by output), suggestions will be generic:
- check your boundary conditions for pressure - try PCG instead of GAMG - try smoothSolver instead of GAMG (if PCG fails) - relax more |
file k:
dimensions [ 0 2 -2 0 0 0 0 ]; internalField uniform 0.0937; boundaryField { inlet { type zeroGradient; } outlet { type zeroGradient; } wall { type kqRWallFunction; value uniform 0.0937; } } fvSolution file: FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-04; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; mergeLevels 1; } pFinal { $p; tolerance 1e-04; relTol 0; } "(U|k|epsilon|R|nuTilda)" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-03; relTol 0; } } PISO { nCorrectors 2; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; } please let me know if any other file is required to figure out my mistakes. thanks alot. |
Then let's start with checkMesh output.
checkMesh output
Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 2568811 faces: 7618500 internal faces: 7531500 cells: 2525000 faces per cell: 6 boundary patches: 3 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 2525000 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 12500 12601 ok (non-closed singly connected) outlet 12500 12601 ok (non-closed singly connected) wall 62000 62200 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-0.10325 -0.10325 -4.1325) (0.10325 0.10325 4.1325) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (1.6254e-16 7.6806e-16 -7.61097e-17) OK. ***High aspect ratio cells found, Max aspect ratio: 7.13865e+195, number of cells 79032 <<Writing 79032 cells with high aspect ratio to set highAspectRatioCells Minimum face area = 6.05538e-11. Maximum face area = 0.000153586. Face area magnitudes OK. ***Zero or negative cell volume detected. Minimum negative volume: -8.8737e-08, Number of negative volume cells: 77272 <<Writing 77272 zero volume cells to set zeroVolumeCells Mesh non-orthogonality Max: 180 average: 24.3587 *Number of severely non-orthogonal (> 70 degrees) faces: 87760. ***Number of non-orthogonality errors: 225000. <<Writing 312760 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 463928 faces are incorrectly oriented. <<Writing 247308 faces with incorrect orientation to set wrongOrientedFaces ***Max skewness = 871.985, 1056 highly skew faces detected which may impair the quality of the results <<Writing 1056 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 5 mesh checks. End |
Now you know what to do: fix your mesh first. Then you can try to proceed with simulation. Since I do not know where did you get your mesh, I can not suggest a way to fix it.
thanks. i hope i fix it.
