March 24, 2018, 11:43 |
Cyclic BC produces wrong results in OF
cyln
Rep Power: 9 |
Dear OpenFOAM community,
I was using cyclic BC in OF for one of my simulations. However, next to the cyclic boundaries, I was getting an unexpected gradient in my flow parameters. Then, I decided to do a benchmark study whose pictures are attached. I am getting the same gradient next to the cyclic boundaries in the benchmark study as well. The same situation is present for slip wall BC, however, since I need to figure out how to make cyclic BC work in OF, first I would like to know why this gradient occurs. I generate my mesh in ICEM, and then convert it to foam mesh using fluent3DMeshToFoam. Then, I use createPatch utility to generate the cyclic boundary condition. In openfoam, I am using pimpleFoam solver. People have been using the cyclic boundary condition in OpenFOAM for their research for a long time. Has someone ever experienced this issue? Do you know why this gradient is happening? If nobody knows the answer, how can we trust OpenFOAM ?!? Cheers, Cyln |
March 26, 2018, 03:03 |
It looks like you are looking at interpolated data. Do you see the gradient also when there is not interpolation? I am not sure which post-processing utility you are using, but in ParaView you can select point values or cell values. You should use the latter for these kind of checks. Regards, Tom |
March 26, 2018, 08:53 |
cyln
Rep Power: 9 |
It is not an interpolation problem. The cyclic BC is not correctly imposed as I get unusual values when I check point values as well. The post processing tool is Tecplot.
March 26, 2018, 09:08 |
I meant you should look at cell values, not at point values. Because you also have a gradient next to your slip wall now, which makes no sense either. Regards, Tom |
Cyclic Boundary Condition Errors? | nyflyer | OpenFOAM Running, Solving & CFD | 2 | April 26, 2016 14:14 |
whats wrong with my hypermesh mapping cfd results | zzyan | Main CFD Forum | 5 | February 1, 2014 12:19 |
Cyclic boundary giving wrong gradient | rakue | OpenFOAM | 0 | November 15, 2013 08:41 |
Wrong wall distance with cyclic boundaries | sebastian | OpenFOAM Bugs | 4 | October 31, 2012 10:24 |
Wrong results in simulations of a propeller by simpleSRFFoam | crazy_cssrc | OpenFOAM | 0 | September 14, 2011 21:11 |
