Multi porous material simulation with porousSimpleFoam
1 Attachment(s)
Hello everyone
I am trying to simulate airflow in a porous material with 3 different porosities. As you can see in the attached picture there are three squares with different porosities stick to each other. they are named from left to right, one, two and three The mesh is imported from Gambit and 3 squares are defined in topoSetDict. I also defined these 3 zones in cellZones and until now everything is OK. I defined Porosity properties in constant folder in this way: Code:
/*--------------------------------*- C++ -*----------------------------------*\ Code:
Create time Thanks for your help |
Hey,
count your brackets in your porosityProperties; Code:
porosity1 In your code the closing brackets for the first two zones are missing... |
