compressibleInterFoam - Boundary Condition
Old   August 17, 2016, 12:57
Default compressibleInterFoam - Boundary Condition
chemcfd
chemcfd is on a distinguished road
Hi, I am trying to run a case in compressibleInterFoam using the following boundary conditions but I face the following error: "Maximum number of iterations exceeded".
Total run time is 1000 s but it crashes at 0.8 s. I guess there is a problem with the boundary conditions. I greatly appreciate your suggestions to correct my boundary conditions.
I need to add that I try to set constant velocity at the inlet and no slip at the walls (grains). Operating pressure is 4.6e5 Pa at constant temperature of 300 K. Fluids are air and water.
U: constant velocity
| \\ / O peration | Version: 3.0.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type fixedValue;
value uniform (-5e-5 0 0);
outlet
type zeroGradient;
grains
type fixedValue;
value uniform (0 0 0);
frontAndBackPlanes
type empty;
alpha.water:
FoamFile
version 2.0;
format ascii;
class volScalarField;
object alpha.water;
dimensions [0 0 0 0 0 0 0];
internalField uniform 0;
boundaryField
grains
type constantAlphaContactAngle;
theta0 45;
limit gradient;
value uniform 0;
inlet
type fixedValue;
value uniform 0;
outlet
type zeroGradient;
frontAndBackPlanes
type empty;
p:
FoamFile
version 2.0;
format ascii;
object p;
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 4.5e6;
boundaryField
grains
type zeroGradient;
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 4.5e6;
frontAndBackPlanes
type empty;
p_rgh:
FoamFile
version 2.0;
format ascii;
object p_rgh;
boundaryField
grains
type zeroGradient;
inlet
type zeroGradient;
outlet
type fixedValue;
frontAndBackPlanes
type empty;
T:
FoamFile
version 2.0;
format ascii;
object T;
dimensions [0 0 0 1 0 0 0];
internalField uniform 300;
boundaryField
grains
type zeroGradient;
inlet
type fixedValue;
value uniform 300;
outlet
type zeroGradient;
frontAndBackPlanes
type empty;
chemcfd is offline   Reply With Quote
Old   August 18, 2016, 10:08
TobM is on a distinguished road
It seems you have a 2D case. Please compare your settings with one of the tutorials for compressibleInterFoam, like damBreak tutorial.
See where they differ and change your case files accordingly.
Post the files please in code tags, makes it more easily to read.
Output of checkMesh and the log file, at least the last few iterations/time steps would be useful.
TobM is offline   Reply With Quote
Old   September 8, 2016, 22:33
Question
Sam Salehian
SmokedJuggler is on a distinguished road
Hello everyone,
I am using CompressibleInterFoam for a test case of a rectangular computational domain. I have two walls on the left boundary and an Inlet in the middle. Top and Bottom Patches are free surfaces. And the Right patch is outlet. And as a test case I initialize all the regions to be air.
The temperature decreases rapidly but does not become negative anymore. However, I am getting the following error:
Courant Number mean: 0.017525563 max: 0.36055112
deltaT = 3.1316128e-05
Time = 0.01149259369
PIMPLE: iteration 1
MULES: Solving for alpha.water
Liquid phase volume fraction = 0.99838497  Min(alpha.water) = 0  Min(alpha.air) = -6.1014024e-05
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver:  Solving for T, Initial residual = 0.0020526023, Final residual = 0.0023329173, No Iterations 1000
min(T) 0.93072415
GAMG:  Solving for p_rgh, Initial residual = 0.17359627, Final residual = 6.6372495e-05, No Iterations 1
max(U) 34.502714
min(p_rgh) 52859.589
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3  Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#4  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
#5  Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
#6  ? at ??:?
#7  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#8  ? at ??:?
Floating point exception (core dumped)
My B.C are:
alpha.water
    object      alpha.water;
boundaryField
    FrontAndBack
        type            empty;
    Inlet
        type            zeroGradient;
    Outlet
        type            zeroGradient;
    TopAndBottomPatches
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    Walls
        type            zeroGradient;
U:
boundaryField
    FrontAndBack
        type            empty;
    Inlet
        type            fixedValue;
        value           uniform (10 0 0);
    Outlet
        type            zeroGradient;
    TopAndBottomPatches
        type            pressureInletOutletVelocity;
    Walls
        type            noSlip;
p:
internalField   uniform 1e5;
boundaryField
    FrontAndBack
        type            empty;
    Inlet
        type            zeroGradient;
    Outlet
        type            fixedValue;
        value           uniform 1e5;
    TopAndBottomPatches
        type            totalPressure;
        p0              uniform 1e5;
    Walls
        type            zeroGradient;
p_rgh
boundaryField
    FrontAndBack
        type            empty;
    Inlet
        type            zeroGradient;
    Outlet
        type            fixedValue;
        value           uniform 1e5;
    TopAndBottomPatches
        type            totalPressure;
        p0              uniform 1e5;
    Walls
        type            fixedFluxPressure;
        value           uniform 0;
T
boundaryField
    FrontAndBack
        type            empty;
    Inlet
        type            fixedValue;
        value           uniform 300;
    Outlet
        type            zeroGradient;
    TopAndBottomPatches
        type            zeroGradient;
    Walls
        type            zeroGradient;
I would appreciate if someone could give me some guidance on how to resolve the issue and help me understand why this error is happening.
Thanks to all,
SmokedJuggler is offline   Reply With Quote
Old   September 9, 2016, 02:11
p is calculated from p_rgh so p has to be type calculated everywhere as in the tutorial cases.
When you use compressibleInterFoam it makes no sense just to simulate air. At least a little bit of alpha.water somewhere in your domain would help.
boundary condition, compressibleinterfoam
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Centrifugal fan j0hnny CFX 13 October 1, 2019 13:55
Accessing multiple boundary patches from a custom boundary condition file ripudaman OpenFOAM Programming & Development 0 October 22, 2014 18:34
Radiation interface hinca CFX 15 January 26, 2014 17:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
