January 18, 2013, 04:02 |
Questions on dynamicTopoFvMesh
Daniele Vicario
Rep Power: 17 |
I'm trying to understand how to use dynamicTopoFvMesh library to simulate a free moving (6DoF) object into a fluid. I'm following the circCylinder3d tutorial just to understand how to setup my case that will use pimpleDyMFoam and I've got lots of questions... just a couple to start: 1. What is tetFemSolution ? 2. In dynamicMeshDict there are position constrains: Code:
//- Constrain surface mesh-motion on a specified cylinder cylindricalConstraints { //- Specify options per slip patch sideWall { axisPoint (0.0 0.0 0.0); axisVector (0.0 0.0 1.0); radius 1.0; } } //- Specify fixedValue patches for the motionSolver fixedValuePatches { topWall { type angularOscillatingDisplacement; amplitude -0.0125; //type oscillatingDisplacement; //amplitude (0 0 -0.01); axis (1 0 0); origin (0 0 3); angle0 0.0; omega 0.15; value uniform (0 0 0); } } Code:
boundaryField { bottomWall { type fixedValue; value uniform (0 0 0); } sideWall { type slip; } topWall { type oscillatingFixedValue; refValue uniform (0 0 0); amplitude uniform (0 0 0.5); frequency 0.1; //type fixedValue; //value uniform (0 0 0.1); } outlet { type fixedValue; value uniform (0 0 0); } } // angularOscillatingDisplacement // angularOscillatingVelocity // oscillatingDisplacement // oscillatingVelocity // surfaceDisplacement // surfaceSlipDisplacement Is there something similar to the following type ? Code:
oggetto { type sixDoFRigidBodyDisplacement; centreOfMass (0 0 0.2); momentOfInertia (0.000001 0.000001 0.000001); mass 0.01; rhoName rhoInf; rhoInf 1000; // needed only for solvers solving for kinematic pressure report on; value uniform (0 0 0); } Thanks.
Daniele Vicario blueCFD2.1 - Windows 7 |
January 18, 2013, 10:14 |
Sandeep Menon
Rep Power: 25 |
Daniele,
Sorry if the whole thing was confusing to you. I'll briefly explain: 1. The tetFemSolution file is for the tetDecompositionMotionSolvers in OpenFOAM-1.6-ext. If you don't use that library, then this file has no effect, since the mesquiteMotionSolver does not use it any way. 2. The motionU file is a way for motionSolvers to input boundary conditions, and again, is not used by the mesquiteMotionSolver, and is input using dynamicMeshDict instead. However, it appears that the fixedValuePatches approach is too simplistic, and using more complicated patch fields like sixDoFRigidBodyDisplacement may not work this way (this particular patch writes the initial position to disk, which is required for solution restarts). I've attached a diff patch which I've tested only briefly with the Port-2.1.x branch of the github repository - for some reason, it doesn't work with OF-1.6-ext. This patch basically points the mesquiteMotionSolver to use the pointDisplacement field (which the fvMotionSolver uses) to calculate 6-DoF properties. 3. Remember to add a libs entry in your controlDict that loads libforces.so (located at $FOAM_SRC/postProcessing/functionObjects/forces, if you're curious), so that the 6DoF stuff is picked up, and those patches become available for run time selection. Hope this helps. |
January 18, 2013, 12:09 |
Daniele Vicario
Rep Power: 17 |
Hi Sandeep,
many thanks for the clarifications ! I'll try the patch and let you know.
January 18, 2013, 13:59 |
Daniele Vicario
Rep Power: 17 |
It give me a strange error:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ /* Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt *\ | Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com | \*---------------------------------------------------------------------------*/ Build : 2.1-fb1015c3f1b5 Exec : C:\PROGRA~2\BLUECF~1.1\OpenFOAM-2.1\platforms\linuxmingw-w64DPOpt\bin\pimpleDyMFoam.exe Date : Jan 18 2013 Time : 18:50:58 Host : "UFFTECNICO7" PID : 5668 Case : f:/taps/cfd/valvmov-topo nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh dynamicTopoFvMesh Selecting metric Knupp Selecting motion solver: mesquiteMotionSolver Selecting quality metric: AspectRatioGamma Selecting objective function: LPtoP Selecting optimization algorithm: FeasibleNewton Outer termination criterion (tcOuter) was not found. Using default values. Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Reading field rAU if present No field sources present PIMPLE: no residual control data found. Calculations will employ 2 corrector loops Starting time loop Courant Number mean: 0.001961305481 max: 0.207096507 deltaT = 0.001111111111 Time = 0.00111111 ************** QualityAssessor(free only) Summary ************** Evaluating quality for 72062 free elements of 72220 total elements. There were no inverted elements detected. No entities had undefined values for any computed metric. metric minimum average rms maximum std.dev. AspectRatioGamma 1.001149442 1.201508832 1.208379622 3.0127907370.1286772598 ************** QualityAssessor(free only) Summary ************** Evaluating quality for 72062 free elements of 72220 total elements. There were no inverted elements detected. No entities had undefined values for any computed metric. metric minimum average rms maximum std.dev. AspectRatioGamma 1.001124721 1.201507976 1.208379044 3.0144733790.1286798298 ~~~ Mesh Quality Statistics ~~~ Min: 0.4792098079 Max: 0.9992508882 Mean: 0.8898675635 Cells: 72220 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Topo modifier time: 0.648 s Bisections :: Total: 0, Surface: 0 Collapses :: Total: 0, Surface: 0 Swaps :: Total: 441, Surface: 0 --> FOAM FATAL ERROR: attempted to assign to a const reference to constant object From function Foam::tmp<T>::operator=(const tmp<T>&) in file C:/PROGRA~2/BLUECF~1.1/OpenFOAM-2.1/src/OpenFOAM/lnInclude/tmpI.H at line 270. FOAM aborting Backtrace: ZN10StackTraceC1Ev [0x6c5815de+62] module: C:\PROGRA~2\BLUECF~1.1\OpenFOAM-2.1\platforms\linuxmingw-w64DPOpt\lib\libstack_trace.dll (No symbol) [0x44ed1a0] RtlCaptureContext [0x775eb6f0+0] module: C:\Windows\system32\kernel32.dll (No symbol) [0x76cc10] (No symbol) [0x590270] (No symbol) [0x5904a0] (No symbol) [0x1b] (No symbol) [0x7602a8] RtlAllocateHeap [0x77cd3488+232] module: C:\Windows\SYSTEM32\ntdll.dll This application has requested the Runtime to terminate it in an unusual way. Please contact the application's support team for more information. Here you can find the case: https://www.box.com/s/9pg0lcuhu20th8cnccfh Thanks for any help.
January 18, 2013, 15:27 |
Sandeep Menon
Rep Power: 25 |
Anyway you could give me a more meaningful stack trace? I you compile with debug symbols, that would be helpful.
I think I might have seen this error before. Perhaps the attached diff would help. Not sure if this is the same problem though. |
January 18, 2013, 18:07 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Sandeep: Your latest patch "topoMapperTemplates.patch" fixed the problem! Sorry about the nearly meaningless stack trace. I'm the guy responsible for this OpenFOAM port named blueCFD, and this particular version Daniele is using is still a preview version, for which the stack trace is still very flaky. Although it's not necessary but as future reference, on Linux (Ubuntu 12.04 x86_64), the respective stack trace was this (although not using debug symbols): Code:
#0 Foam::error::printStack(Foam::Ostream&) in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::error::abort() in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 void Foam::topoMapper::storeGradients<Foam::Vector<double>, Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> >(Foam::HashTable<Foam::autoPtr<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> >, Foam::word, Foam::string::hash>&) const in "/home/user/OpenFOAM/user-2.1.x/platforms/linux64GccDPOpt/lib/libdynamicTopoFvMesh.so" #3 Foam::topoMapper::storeGradients() const in "/home/user/OpenFOAM/user-2.1.x/platforms/linux64GccDPOpt/lib/libdynamicTopoFvMesh.so" #4 Foam::topoMapper::storeMeshInformation() const in "/home/user/OpenFOAM/user-2.1.x/platforms/linux64GccDPOpt/lib/libdynamicTopoFvMesh.so" #5 Foam::dynamicTopoFvMesh::resetMesh() in "/home/user/OpenFOAM/user-2.1.x/platforms/linux64GccDPOpt/lib/libdynamicTopoFvMesh.so" #6 Foam::dynamicTopoFvMesh::update() in "/home/user/OpenFOAM/user-2.1.x/platforms/linux64GccDPOpt/lib/libdynamicTopoFvMesh.so" #7 in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/pimpleDyMFoam" #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/pimpleDyMFoam" Aborted (core dumped) Bruno
January 19, 2013, 04:01 |
Daniele Vicario
Rep Power: 17 |
Thanks to both Bruno and Sandeep!
But I still have problems: I cleared all the position BC from dynamicMeshDict and I used the following pointDisplacement dict: Code:
dimensions [0 1 0 0 0 0 0]; internalField uniform (0 0 0); boundaryField { wall { type fixedValue; value uniform (0 0 0); } inlet { type fixedValue; value uniform (0 0 0); } outlet { type fixedValue; value uniform (0 0 0); } oggetto { type sixDoFRigidBodyDisplacement; centreOfMass (0 0 0.2); momentOfInertia (0.000001 0.000001 0.000001); mass 0.01; rhoName rhoInf; rhoInf 1000; // needed only for solvers solving for kinematic pressure report on; value uniform (0 0 0); } } Code:
//- Select the type of dynamicFvMesh dynamicFvMesh dynamicTopoFvMesh; //- Select the type of motionSolver motionSolverLibs ("libmesquiteMotionSolver.so" "libfvMotionSolvers.so"); solver mesquiteMotionSolver; mesquiteOptions { //- Optimization metric optMetric AspectRatioGamma; //- Objective function objFunction LPtoP; //- Optimization algorithm optAlgorithm FeasibleNewton; tcInner { absGradL2 1e-4; cpuTime 0.5; } //- Power value for the LPtoP objective function pValue 2; power 2; //- Specify a tolerance for the surface-smoothing CG solver tolerance 1e-2; //- Specify number of CG sweeps for surface-smoothing nSweeps 2; //- Specify slip patches for the motionSolver slipPatches { } //- Constrain surface mesh-motion on a specified cylinder cylindricalConstraints { } //- Specify fixedValue patches for the motionSolver fixedValuePatches { } //- Specify interval for surface smoothing surfInterval 1; } //- Options for dynamicTopoFvMesh dynamicTopoFvMesh { allOptionsMandatory no; //debug 2; //- Specify the number of threads threads 1; //- Specify re-meshing interval //- Negative value implies no re-meshing interval 1; //- Specify whether the length-scale field //- should be dumped to disk dumpLengthScale false; //- sliverThreshold specifies the //- quality criteria for sliver removal. sliverThreshold 0.35; //- Should the tool attempt to remove slivers //- that fall below the sliverThreshold value? removeSlivers false; //- Skip mapping step. Useful while using //- this tool as a pre-processor // skipMapping true; // Toggle edgeRefinement on/off edgeRefinement off; refinementOptions { collapseRatio 0.5; bisectionRatio 1.5; growthFactor 1.0; fixedLengthScalePatches { oggetto 0.2; } //- Avoid refinement on certain patches, if necessary noModificationPatches { inlet; outlet; wall; oggetto; } //- Set floating length-scale values on certain patches freeLengthScalePatches { inlet; outlet; wall; } } //- Tetrahedral mesh quality metric tetMetric Knupp; //- Avoid 2-2 swapping on certain patches noSwapPatches {} } If I then modified dynamicMeshDict adding the same position BC: Code:
fixedValuePatches { oggetto { type sixDoFRigidBodyDisplacement; centreOfMass (0 0 0.2); momentOfInertia (0.000001 0.000001 0.000001); mass 0.01; rhoName rhoInf; rhoInf 1000; // needed only for solvers solving for kinematic pressure report on; value uniform (0 0 0); } } Code:
Create time Create mesh for time = 0 Selecting dynamicFvMesh dynamicTopoFvMesh Selecting metric Knupp Selecting motion solver: mesquiteMotionSolver Selecting quality metric: AspectRatioGamma Selecting objective function: LPtoP Selecting optimization algorithm: FeasibleNewton Outer termination criterion (tcOuter) was not found. Using default values. Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Reading field rAU if present No field sources present PIMPLE: no residual control data found. Calculations will employ 2 corrector loops Starting time loop Courant Number mean: 0.001961305481 max: 0.207096507 deltaT = 0.001 Time = 0.001 Centre of mass: (0 0 0.2) Linear velocity: (0 0 0) Angular velocity: (0 0 0) ************** QualityAssessor(free only) Summary ************** Evaluating quality for 72062 free elements of 72220 total elements. There were no inverted elements detected. No entities had undefined values for any computed metric. metric minimum average rms maximum std.dev. AspectRatioGamma 1.001149442 1.201508832 1.208379622 3.0127907370.1286772598 ************** QualityAssessor(free only) Summary ************** Evaluating quality for 72062 free elements of 72220 total elements. There were no inverted elements detected. No entities had undefined values for any computed metric. metric minimum average rms maximum std.dev. AspectRatioGamma 1.001124721 1.201507976 1.208379044 3.0144733790.1286798298 ~~~ Mesh Quality Statistics ~~~ Min: 0.4792098079 Max: 0.9992508882 Mean: 0.8898675635 Cells: 72220 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Topo modifier time: 0.441044 s Bisections :: Total: 0, Surface: 0 Collapses :: Total: 0, Surface: 0 Swaps :: Total: 441, Surface: 0 Mapping time: 0.051005 s Reordering time: 0.135013 s ~~~ No flux correction ~~~ ~~~ Mesh Quality Statistics ~~~ Min: 0.4792098079 Max: 0.9992508882 Mean: 0.8888376015 Cells: 72226 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ GAMG: Solving for pcorr, Initial residual = 1, Final residual = 0.009784238691, No Iterations 14 GAMG: Solving for pcorr, Initial residual = 0.1318015667, Final residual = 0.005524330453, No Iterations 1 GAMG: Solving for pcorr, Initial residual = 0.0274078549, Final residual = 0.001671230422, No Iterations 1 time step continuity errors : sum local = 0.003519238986, global = 2.951992158e-005, cumulative = 2.951992158e-005 PIMPLE: iteration 1 DILUPBiCG: Solving for Ux, Initial residual = 0.2099944886, Final residual = 0.001067176115, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.2176037194, Final residual = 0.001119524463, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.9144495281, Final residual = 0.006921714113, No Iterations 1 GAMG: Solving for p, Initial residual = 1, Final residual = 0.006135893841, No Iterations 16 GAMG: Solving for p, Initial residual = 0.2245647768, Final residual = 0.001579813968, No Iterations 2 GAMG: Solving for p, Initial residual = 0.04407841501, Final residual = 0.0004149844197, No Iterations 2 time step continuity errors : sum local = 0.0005491589084, global = 1.44487661e-005, cumulative = 4.396868768e-005 PIMPLE: iteration 2 DILUPBiCG: Solving for Ux, Initial residual = 0.4474193232, Final residual = 9.817080748e-007, No Iterations 64 DILUPBiCG: Solving for Uy, Initial residual = 0.4486384426, Final residual = 7.49347033e-007, No Iterations 61 DILUPBiCG: Solving for Uz, Initial residual = 0.6700159044, Final residual = 8.998574123e-007, No Iterations 61 GAMG: Solving for p, Initial residual = 0.2749979373, Final residual = 0.001482151148, No Iterations 14 GAMG: Solving for p, Initial residual = 0.1748427853, Final residual = 0.001382902354, No Iterations 2 GAMG: Solving for p, Initial residual = 0.03707025143, Final residual = 4.711430883e-008, No Iterations 22 time step continuity errors : sum local = 5.367153172e-007, global = -5.911960027e-008, cumulative = 4.390956808e-005 ExecutionTime = 8.398 s ClockTime = 9 s Courant Number mean: 1.488762178 max: 300.8061065 deltaT = 1.639344262e-005 Time = 0.00101639 Centre of mass: (0 0 0.2) Linear velocity: (4.896733259e-005 2.424161936e-005 0.006302055408) Angular velocity: (2.485263244e-005 -0.0001594212928 -4.137107884e-005) ************** QualityAssessor(free only) Summary ************** Evaluating quality for 72068 free elements of 72226 total elements. There were no inverted elements detected. No entities had undefined values for any computed metric. metric minimum average rms maximum std.dev. AspectRatioGamma 1.001124721 1.203706166 1.21061955 3.0144733790.1291942728 Last question / problem: I made the tests with: edgeRefinement off; I think I don't need it so far. However when I enable the refinement it returns an error (see enclosed file). Any idea or comment ?
Daniele Vicario blueCFD2.1 - Windows 7 Last edited by danvica; January 19, 2013 at 06:07. |
January 19, 2013, 06:23 |
Daniele Vicario
Rep Power: 17 |
A small update:
@Sandeep: in the first patch you sent me there was an additional flag called "usePointDisplacement". Code:
if (optionsDict.found("usePointDisplacement")) + { + boundaryConditions_.reset + ( + new pointVectorField + ( + IOobject + ( + "pointDisplacement", + Mesh_.time().timeName(), + Mesh_, + IOobject::MUST_READ, + IOobject::AUTO_WRITE + ), + pointMesh::New(Mesh_) + ) + ); + } I tried but it returns more or less the same error: Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ /* Windows 32 and 64 bit porting by blueCAPE: http://www.bluecape.com.pt *\ | Based on Windows porting (2.0.x v4) by Symscape: http://www.symscape.com | \*---------------------------------------------------------------------------*/ Build : 2.1-fb1015c3f1b5 Exec : C:\PROGRA~2\BLUECF~1.1\OpenFOAM-2.1\platforms\linuxmingw-w64DPOpt\bin\pimpleDyMFoam.exe Date : Jan 19 2013 Time : 11:16:40 Host : "UFFTECNICO7" PID : 5212 Case : f:/taps/cfd/valvmov-topo nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh dynamicTopoFvMesh Selecting metric Knupp Selecting motion solver: mesquiteMotionSolver Selecting quality metric: AspectRatioGamma Selecting objective function: LPtoP Selecting optimization algorithm: FeasibleNewton Outer termination criterion (tcOuter) was not found. Using default values. Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Reading field rAU if present No field sources present PIMPLE: no residual control data found. Calculations will employ 2 corrector loops Starting time loop Courant Number mean: 1.961305481e-005 max: 0.00207096507 deltaT = 1.19047619e-005 Time = 1.19048e-005 Centre of mass: (0 0 0.2) Linear velocity: (0 0 0) Angular velocity: (0 0 0) Solving for point motion: Initial residual: 1 Final residual: 0.007879279805 No Iterations: 12 Solving for point motion: Initial residual: 1 Final residual: 0.005761454167 No Iterations: 18 ************** QualityAssessor(free only) Summary ************** Evaluating quality for 72062 free elements of 72220 total elements. There were no inverted elements detected. No entities had undefined values for any computed metric. metric minimum average rms maximum std.dev. AspectRatioGamma 1.000929751 1.202198694 1.20924222 3.0127907370.1303266922 ************** QualityAssessor(free only) Summary ************** Evaluating quality for 72062 free elements of 72220 total elements. There were no inverted elements detected. No entities had undefined values for any computed metric. metric minimum average rms maximum std.dev. AspectRatioGamma 1.001152746 1.202272074 1.209234895 3.0212553940.1295796677 ~~~ Mesh Quality Statistics ~~~ Min: 0.4784923963 Max: 0.9992322401 Mean: 0.8895440621 Cells: 72220 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Topo modifier time: 0.443 s Bisections :: Total: 0, Surface: 0 Collapses :: Total: 0, Surface: 0 Swaps :: Total: 472, Surface: 0 Mapping time: 0.058 s Reordering time: 0.139 s ~~~ No flux correction ~~~ ~~~ Mesh Quality Statistics ~~~ Min: 0.4784923963 Max: 0.9992322401 Mean: 0.8884998041 Cells: 72226 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ GAMG: Solving for pcorr, Initial residual = 1, Final residual = 0.008812231801, No Iterations 14 GAMG: Solving for pcorr, Initial residual = 0.131029343, Final residual = 0.00548001763, No Iterations 1 GAMG: Solving for pcorr, Initial residual = 0.02724234412, Final residual = 0.001672274306, No Iterations 1 time step continuity errors : sum local = 4.373115074e-005, global = 4.508582388e-007, cumulative = 4.508582388e-007 PIMPLE: iteration 1 DILUPBiCG: Solving for Ux, Initial residual = 0.8981178464, Final residual = 0.02090304535, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.8276717749, Final residual = 0.01968424129, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.7550246921, Final residual = 0.01660081128, No Iterations 1 GAMG: Solving for p, Initial residual = 1, Final residual = 0.007054332566, No Iterations 14 GAMG: Solving for p, Initial residual = 0.1219790556, Final residual = 0.000873474047, No Iterations 2 GAMG: Solving for p, Initial residual = 0.02592907917, Final residual = 0.0002061318523, No Iterations 2 time step continuity errors : sum local = 5.656009101e-006, global = 2.517583376e-007, cumulative = 7.026165764e-007 PIMPLE: iteration 2 DILUPBiCG: Solving for Ux, Initial residual = 0.2348991934, Final residual = 8.590299483e-007, No Iterations 4 DILUPBiCG: Solving for Uy, Initial residual = 0.233874458, Final residual = 8.983213027e-008, No Iterations 5 DILUPBiCG: Solving for Uz, Initial residual = 0.089038337, Final residual = 5.353018298e-008, No Iterations 5 GAMG: Solving for p, Initial residual = 0.0406207147, Final residual = 0.000269779655, No Iterations 8 GAMG: Solving for p, Initial residual = 0.06275711829, Final residual = 0.0005373520539, No Iterations 2 GAMG: Solving for p, Initial residual = 0.01329922478, Final residual = 5.808675466e-008, No Iterations 17 time step continuity errors : sum local = 1.18446448e-009, global = -2.537820206e-010, cumulative = 7.023627944e-007 ExecutionTime = 6.299 s ClockTime = 6 s Courant Number mean: 0.1408376737 max: 2.181599535 deltaT = 1.411564626e-005 Time = 2.60204e-005 Backtrace: ZN10StackTraceC1Ev [0x6c5815de+62] module: C:\PROGRA~2\BLUECF~1.1\OpenFOAM-2.1\platforms\linuxmingw-w64DPOpt\lib\libstack_trace.dll (No symbol) [0x4148d40] RtlCaptureContext [0x775eb6f0+0] module: C:\Windows\system32\kernel32.dll (No symbol) [0x22ff30] (No symbol) [0x68e0000] (No symbol) [0x3342c10] (No symbol) [0x5d12f0] (No symbol) [0x5e0080] (No symbol) [0x48923b0] (No symbol) [0x6bee310] (No symbol) [0x48923c0] (No symbol) [0x19200010000f] (No symbol) [0x53002b002b0033] (No symbol) [0x206002b002b] (No symbol) [0x3f1] (No symbol) [0x100000300] (No symbol) [0x7e]
January 19, 2013, 15:05 |
#9 |
Bruno Santos
Rep Power: 128 |
Hi!
First note: I don't know how to help Daniele any further on how to set-up this case for having the loose object float away with the flow. I'm only able so far to diagnose why things were crashing. Second note: Just to inform readers that I've already sent an email to Daniele informing about the problems that were happening with this case in particular, at least about the error itself. In summary:
Bruno
January 20, 2013, 11:35 |
#10 |
Daniele Vicario
Rep Power: 17 |
first I want to thank Bruno for the support. Then, just to complete the thread, I enclose some pictures of the mesh. It's a simple two diameter pipe, with a sphere inside of the bigger diameter part. In order to mesh it using just tet elements I used Netgen. Everything was fine for checkmesh (skew and not-orto) but I hadn't check the small-determinant cells. I don't know why normally these faulty cells are not so important...or maybe they are and they are the hidden cause of lots of crashes... or maybe it's just me that I'm stick to Windows. However the main problem is that I don't know how to refine the mesh in order to avoid them. You can see their position in the last picture (white coloured). I neither don't know what caused them. The geometry is quite simple and I cannot understand how Netgen can create such cells in those (simple) position. I googled a little but there's not so many information avaible on the topic. BTW I tried: Netgen itself: mesh resolution seems to have no correlation with the number of null-determinant cells. GMsh, Engrid: Windows version are too instables. MeshLab: Still studying it. Help needed Salome: I wanted to locally refine the edges but it crash immediately. Anyway I'll leave this thread,for now, and I'll create another in the right meshing forum to try to solve this problem. I'll come back asap. But if you have any idea post it wherever you want !!
January 21, 2013, 10:01 |
#11 |
Sandeep Menon
Rep Power: 25 |
Daniele,
If I vaguely recall, I remember having trouble with objects falling under gravity using pimpleDyMFoam as well, and that using interDyMFoam (with a bogus alpha field of all fluid) seemed to fix the problem. Again, this is a little weird since gravity is supposed to be picked up from the boundary condition in pimpleDyMFoam, and there's some funky settings where a registered gravity field is sometimes used instead. You may want to also check if pressure is being dealt with in a consistent manner for both situations. Your 'cells with small determinants' seems okay to me from a visual observation, and if checkMesh gives you a decent non-orthogonality, you should be good on that front. I've run meshes with far worse and still succeeded. |
January 21, 2013, 10:47 |
#12 |
Daniele Vicario
Rep Power: 17 |
Thanks for your support Sandeep.
I will definitely try interDyMFoam but so far the main problem seems caused by the 0-det cells. Bruno made a deep analysis of the issue that, I want to confirm, happens just on this Windows porting. In few words, it brings to an out-of-range array access. Linux manages better than Windows this kind of problems. I'm still looking for a way to get rid of this cells but, as you said, normally OF can manage worse meshes without problems: I don't know if I'm going to find the right tool. Thanks.
January 28, 2013, 18:02 |
#13 |
Bruno Santos
Rep Power: 128 |
Greetings to all!
I've finally managed to figure out what's wrong! And I don't have enough experience to fix this . It's not a problem with cell determinant being null or very small... It's the first patch on this thread that's broken! The problem is this part of the patch: Code:
@@ -3583,6 +3604,14 @@ void mesquiteMotionSolver::applyFixedValuePatches() // Fetch the sub-dictionary const dictionary& optionsDict = subDict("mesquiteOptions"); + if (boundaryConditions_.valid()) + { + //boundaryConditions_().boundaryField().updateCoeffs(); + boundaryConditions_().correctBoundaryConditions(); + + refPoints_ += boundaryConditions_().internalField(); + } + else Code:
#0 Foam::error::printStack(Foam::Ostream&) in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigSegv::sigHandler(int) in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::valuePointPatchField<Foam::Vector<double> >::evaluate(Foam::UPstream::commsTypes) in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 Foam::GeometricField<Foam::Vector<double>, Foam::pointPatchField, Foam::pointMesh>::GeometricBoundaryField::evaluate() in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #5 Foam::mesquiteMotionSolver::applyFixedValuePatches() in "/home/user/OpenFOAM/user-2.1.x/platforms/linux64GccDPOpt/lib/libmesquiteMotionSolver.so" #6 Foam::mesquiteMotionSolver::solve() in "/home/user/OpenFOAM/user-2.1.x/platforms/linux64GccDPOpt/lib/libmesquiteMotionSolver.so" #7 Foam::motionSolver::newPoints() in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libdynamicMesh.so" #8 Foam::dynamicTopoFvMesh::update() in "/home/user/OpenFOAM/user-2.1.x/platforms/linux64GccDPOpt/lib/libdynamicTopoFvMesh.so" #9 in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/pimpleDyMFoam" #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #11 in "/home/user/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/pimpleDyMFoam" Segmentation fault (core dumped) Simply run: Code:
pimpleDyMFoam Best regards, Bruno
January 28, 2013, 22:42 |
#14 |
Sandeep Menon
Rep Power: 25 |
Bruno,
Is this after a topology change? If so, could you check if the patch field is being mapped after topo-changes? If not, perhaps the pointMesh mapper is being incorrectly called (or maybe not at all). Thanks |
January 29, 2013, 05:25 |
#15 |
Bruno Santos
Rep Power: 128 |
Hi Sandeep,
I think there are topology changes and some mapping seems to occur... but not for the second iteration, if I understand it correctly. I've used the following debug flags to turn on some more reports on what OpenFOAM does (placed inside the file "~/.OpenFOAM/2.1.x/controlDict"): Code:
DebugSwitches { primitiveMesh 1; mesquiteMotionSolver 1; polyMesh 1; } Code:
Create time Create mesh for time = 0 Selecting dynamicFvMesh dynamicTopoFvMesh void polyMesh::initMesh() : initialising primitiveMesh primitiveMesh::clearGeom() : clearing geometric data primitiveMesh::clearAddressing() : clearing topology primitiveMesh::reset : mesh reset to nInternalPoints:-1 nPoints:14143 nEdges:-1 nInternalFaces:140933 nFaces:147947 nCells:72220 primitiveMesh::calcCells() : calculating cells Selecting metric Knupp primitiveMesh::calcEdges(const bool) : calculating edges, pointEdges and optionally faceEdges primitiveMesh::faceEdges() : calculating faceEdges primitiveMesh::edgeFaces() : calculating edgeFaces Selecting motion solver: mesquiteMotionSolver Reading options for mesquiteMotionSolver Selecting quality metric: AspectRatioGamma Selecting objective function: LPtoP Selecting optimization algorithm: FeasibleNewton Outer termination criterion (tcOuter) was not found. Using default values. Reading field p Reading field U Reading/calculating face flux field phi primitiveMesh::calcFaceCentresAndAreas() : Calculating face centres and face areas primitiveMesh::calcFaceCentresAndAreas() : Finished calculating face centres and face areas polyMesh::globalData() const : Constructing parallelData from processor topology This needs the patch faces to be correctly matched primitiveMesh::calcCellCentresAndVols() : Calculating cell centres and cell volumes primitiveMesh::calcCellCentresAndVols() : Finished calculating cell centres and cell volumes Selecting incompressible transport model Newtonian Selecting turbulence model type laminar Reading field rAU if present No field sources present PIMPLE: no residual control data found. Calculations will employ 2 corrector loops Starting time loop Courant Number mean: 1.961305481e-008 max: 2.07096507e-006 deltaT = 0.001111111111 Time = 0.00111111 nTet = 72220 nHex = 0 nPyr = 0 nPrism = 0 nPolyhedra = 0 Applying fixed-value patches, if any Centre of mass: (0 0 0.2) Linear velocity: (0 0 0) Angular velocity: (0 0 0) ************** QualityAssessor(free only) Summary ************** Evaluating quality for 72062 free elements of 72220 total elements. There were no inverted elements detected. No entities had undefined values for any computed metric. metric minimum average rms maximum std.dev. AspectRatioGamma 1.001149442 1.201508832 1.208379622 3.0127907370.1286772598 ************** QualityAssessor(free only) Summary ************** Evaluating quality for 72062 free elements of 72220 total elements. There were no inverted elements detected. No entities had undefined values for any computed metric. metric minimum average rms maximum std.dev. AspectRatioGamma 1.001124721 1.201507976 1.208379044 3.0144733790.1286798298 ~~~ Mesh Quality Statistics ~~~ Min: 0.4792098079 Max: 0.9992508882 Mean: 0.8898675635 Cells: 72220 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Topo modifier time: 0.365021 s Bisections :: Total: 0, Surface: 0 Collapses :: Total: 0, Surface: 0 Swaps :: Total: 441, Surface: 0 primitiveMesh::calcCellCells() : calculating cellCells Mapping time: 0.042002 s Reordering time: 0.103006 s void polyMesh::clearAddressing() : clearing topology primitiveMesh::clearAddressing() : clearing topology void polyMesh::setInstance(const fileName& inst) : Resetting file instance to "0.00111111" void polyMesh::initMesh() : initialising primitiveMesh primitiveMesh::clearGeom() : clearing geometric data primitiveMesh::clearAddressing() : clearing topology primitiveMesh::reset : mesh reset to nInternalPoints:-1 nPoints:14143 nEdges:-1 nInternalFaces:140945 nFaces:147959 nCells:72226 void polyMesh::clearGeom() : clearing geometric data primitiveMesh::clearGeom() : clearing geometric data void polyMesh::clearAddressing() : clearing topology primitiveMesh::clearAddressing() : clearing topology void polyMesh::updateMesh(const mapPolyMesh&) : updating addressing and (optional) pointMesh/pointFields void polyMesh::setInstance(const fileName& inst) : Resetting file instance to "0.00111111" Mapping volTensorField grad(U) primitiveMesh::calcCellCentresAndVols() : Calculating cell centres and cell volumes primitiveMesh::calcFaceCentresAndAreas() : Calculating face centres and face areas primitiveMesh::calcFaceCentresAndAreas() : Finished calculating face centres and face areas primitiveMesh::calcCellCentresAndVols() : Finished calculating cell centres and cell volumes tmp<scalarField> polyMesh::movePoints(const pointField&) : Moving points for time 0.001111111111 index 1 bool primitiveMesh::checkMeshMotion(const pointField& newPoints, const bool report) const: checking mesh motion Min volume = 3.690509017e-010. Total volume = 0.001987458117. Cell volumes OK. Min area = 8.235135209e-007. Face areas OK. Pyramid volumes OK. Non-orthogonality check OK. Mesh motion check OK. primitiveMesh::clearGeom() : clearing geometric data primitiveMesh::calcCellCentresAndVols() : Calculating cell centres and cell volumes primitiveMesh::calcFaceCentresAndAreas() : Calculating face centres and face areas primitiveMesh::calcFaceCentresAndAreas() : Finished calculating face centres and face areas primitiveMesh::calcCellCentresAndVols() : Finished calculating cell centres and cell volumes ~~~ No flux correction ~~~ tmp<scalarField> polyMesh::movePoints(const pointField&) : Moving points for time 0.001111111111 index 1 bool primitiveMesh::checkMeshMotion(const pointField& newPoints, const bool report) const: checking mesh motion Min volume = 3.698076689e-010. Total volume = 0.001987458117. Cell volumes OK. Min area = 8.244142416e-007. Face areas OK. Pyramid volumes OK. Non-orthogonality check OK. Mesh motion check OK. primitiveMesh::clearGeom() : clearing geometric data primitiveMesh::calcCellCentresAndVols() : Calculating cell centres and cell volumes primitiveMesh::calcFaceCentresAndAreas() : Calculating face centres and face areas primitiveMesh::calcFaceCentresAndAreas() : Finished calculating face centres and face areas primitiveMesh::calcCellCentresAndVols() : Finished calculating cell centres and cell volumes Clearing out mesquiteMotionSolver for topo-changes ~~~ Mesh Quality Statistics ~~~ Min: 0.4792098079 Max: 0.9992508882 Mean: 0.8888376015 Cells: 72226 ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ polyMesh::globalData() const : Constructing parallelData from processor topology This needs the patch faces to be correctly matched GAMG: Solving for pcorr, Initial residual = 1, Final residual = 0.009784238691, No Iterations 14 GAMG: Solving for pcorr, Initial residual = 0.1318015667, Final residual = 0.005524330453, No Iterations 1 GAMG: Solving for pcorr, Initial residual = 0.0274078549, Final residual = 0.001671230422, No Iterations 1 time step continuity errors : sum local = 3.91026554e-008, global = 3.279991287e-010, cumulative = 3.279991287e-010 PIMPLE: iteration 1 DILUPBiCG: Solving for Ux, Initial residual = 0.001776048218, Final residual = 9.263663799e-011, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.001404779735, Final residual = 7.728408671e-011, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.00987428103, Final residual = 8.50084699e-010, No Iterations 1 GAMG: Solving for p, Initial residual = 1, Final residual = 0.009588103798, No Iterations 14 GAMG: Solving for p, Initial residual = 0.1302883199, Final residual = 0.0009036470934, No Iterations 2 GAMG: Solving for p, Initial residual = 0.02737724854, Final residual = 0.0002262485978, No Iterations 2 time step continuity errors : sum local = 5.294873174e-009, global = 1.106183578e-010, cumulative = 4.386174865e-010 PIMPLE: iteration 2 DILUPBiCG: Solving for Ux, Initial residual = 0.1834820032, Final residual = 5.636594204e-007, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.1830492352, Final residual = 5.109273914e-007, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.05322444189, Final residual = 1.831625782e-007, No Iterations 2 GAMG: Solving for p, Initial residual = 0.01625682761, Final residual = 0.0001395819713, No Iterations 10 GAMG: Solving for p, Initial residual = 0.07015457008, Final residual = 0.0004928326396, No Iterations 2 GAMG: Solving for p, Initial residual = 0.01514164752, Final residual = 7.103417641e-008, No Iterations 14 time step continuity errors : sum local = 1.648956177e-012, global = 4.143241703e-013, cumulative = 4.390318106e-010 ExecutionTime = 4.949 s ClockTime = 5 s Courant Number mean: 0.02715254901 max: 0.4297419588 deltaT = 0.00126984127 Time = 0.00238095 primitiveMesh::calcCells() : calculating cells nTet = 72226 nHex = 0 nPyr = 0 nPrism = 0 nPolyhedra = 0 Applying fixed-value patches, if any Bruno
February 3, 2013, 14:53 |
#16 |
Bruno Santos
Rep Power: 128 |
Greetings to all!
@Sandeep: any chance you can (help us) figure out what's missing here? Because after roughly 5h of studying dynamic meshing, studying the "mesquiteMotionSolver" and doing several trial-and-errors... I haven't managed to fix this problem. Attached is a patch with the code where I stopped trying to fix this. In essence, my findings are as follows:
Bruno
February 4, 2013, 00:02 |
#17 |
Sandeep Menon
Rep Power: 25 |
I think I might know why things are not being mapped. The boundaryConditions_ member is instantiated using a pointMesh::New function, which may not be registering itself correctly for all subsequent pointField mapping.
I say this because the only field that is currently being mapped (from your logs) is the volTensorField grad(U). It would be helpful to ensure that the pointMesh exists during the mapping process (in MapGeometricFields.H), so that all pointFields associated with it are mapped accordingly as well. Another possibility is to have the boundaryConditions_ pointVectorField mapped during the mesquiteMotionSolver::update(const mapPolyMesh& mpm) call. I think a pointMapper will need to be instantiated for this, but I can't remember off the top of my head - perhaps you could take a cue from other parts of OpenFOAM, like the fvMotionSolver::updateMesh() functions. |
February 4, 2013, 06:19 |
#18 |
Bruno Santos
Rep Power: 128 |
Hi Sandeep,
Many thanks! I'll look into this further. Best regards, Bruno
February 18, 2013, 19:09 |
#19 |
Bruno Santos
Rep Power: 128 |
Hi Sandeep,
Unfortunately, I'm unable to figure out how to do the point mapping. All of my tests seem to indicate that "boundaryConditions_()" no longer has enough information when it is working inside "void mesquiteMotionSolver::update(const mapPolyMesh& mpm)". Attached is a hack that seems to work, although it has to resort to the file system for storing the "pointDisplacement" field. It's applied on top of your two patches, if I'm not mistaken. It's a (very) sub-optimal solution, but it gets the job done... or at least I hope so. edit: after several iterations, it looks like the sphere is starting to get deformed... I can only guess that it's because there are points that are being erased/added, which are not mapped out with this hack... Best regards, Bruno
February 19, 2013, 10:25 |
#20 |
Sandeep Menon
Rep Power: 25 |
Bruno,
I'm willing to bet that the points on the sphere correspond to un-mapped points. Can you add a noModificationPatches / noSwapPatches entry in dynamicMeshDict with your "sphere" patch, and see if the deformations still happen? If you look at the Foam:: polyMesh::updateMesh(const mapPolyMesh& mpm) function in polyMeshUpdate.C, you'll see this bit: Code:
if (thisDb().foundObject<pointMesh>(pointMesh::typeName)) { const_cast<pointMesh&> ( thisDb().lookupObject<pointMesh> ( pointMesh::typeName ) ).updateMesh(mpm); } |
Display Modes | |
Questions about modeling of a reservoir | hwangpo | CFX | 7 | October 30, 2012 22:46 |
possible interview questions | atturh | Main CFD Forum | 1 | February 21, 2012 09:53 |
Interview Questions | Carna | FLUENT | 0 | December 26, 2011 05:35 |
NACA0012 Validation Case Questions | ozzythewise | Main CFD Forum | 3 | August 3, 2010 15:39 |
Questions about CFD | Lebeau alexandre | Main CFD Forum | 1 | April 6, 1999 15:23 |
