chtMultiRegionSimpleFoam planeWall2D case dont run correctly in OPenFOAM 1606+
Hi all,
i am new to OpenFOAM and have started since May. I try to run the planeWall2D case in the newes version 1606+ but error happens.I download the case from below: https://openfoamwiki.net/index.php/G..._-_planeWall2D When i type allrun the blockMesh and topoSet run correctly. But the log of splitMeshRegions says error. Then i noticed that for the new version of openfoam the container for the BC calculated is necessary and then i add them for all the files in /0 folder. Then the splitMeshRegions runs correctly. But when i open the log of chtMultiRegionSimpleFoam, it says like below: Create time Create fluid mesh for region bottomAir for time = 0 Create fluid mesh for region topAir for time = 0 Create solid mesh for region wall for time = 0 *** Reading fluid mesh thermophysical properties for region bottomAir Adding to thermoFluid Selecting thermodynamics package { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam::perfectGas<Foa m::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:? #4 Foam::rhoThermo::addfvMeshConstructorToTable<Foam: :heRhoThermo<Foam::rhoThermo, Foam::pureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam::perfectGas<Foa m::specie> >, Foam::sensibleEnthalpy> > > > >::New(Foam::fvMesh const&, Foam::word const&) at ??:? #5 Foam::autoPtr<Foam::rhoThermo> Foam::basicThermo::New<Foam::rhoThermo>(Foam::fvMe sh const&, Foam::word const&) at ??:? #6 Foam::rhoThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:? #7 ? at ??:? #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 ? at ??:? Floating point exception (core dumped) I am at the first time here a thread writting so i dont know how to put this in a frame.Sorry for that. Can anyone help me?I really need to make it work. Thx. |
