August 11, 2016, 11:46 |
Magnus force for particle laden flows
Jesus Ramirez
Rep Power: 11 |
Hello foamers,
I am actually working with solid particles inside incompressible flows. As a part of my research I would like to calculate the effect of magnus forces on the particle behaviour. However, at this moment I can not figure out how to calculate torque, angular momentun and angular velocity over the particles in OpenFoam. has anybody worked in this topic?. Any help will be apreciated. Thanks in advance. |
RAS turbulence model in multiphase Euler solver for dilute particle laden flows | openfoammaofnepo | OpenFOAM | 0 | July 4, 2016 17:29 |
Regarding modified drag force formulation for application in dense flows | ansubru | OpenFOAM Programming & Development | 15 | September 14, 2014 09:04 |
Force coeffs in compressible flows | nachettito | OpenFOAM Post-Processing | 0 | August 13, 2012 06:18 |
Derivation of the pressure-correction equation for compressible flows | luftraudi | Main CFD Forum | 0 | July 17, 2012 06:35 |
gravitational force for free surface flow | Jongtae Kim | Main CFD Forum | 1 | July 2, 2000 11:57 |
