problem with fireFoam
2 Attachment(s)
Hello! I beginner with OpenFoam and I have so many questions.
I use fireFoam solver. If I run 2D case (see attachments) its run just fine. But if I try extend it to 3D (change blockMeshDict) fireFoam crashes with system error. I don't understand where my mistake. Should I change something else beside mesh? Please help me. Error: #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/opt/openfoam4/platforms/linuxGccDPInt32Opt/lib/libOpenFOAM.so" #3 Foam::radiation::fvDOM::initialise() at ??:? #4 Foam::radiation::fvDOM::fvDOM(Foam::GeometricField <double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #5 Foam::radiation::radiationModel::addTConstructorTo Table<Foam::radiation::fvDOM>::New(Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #6 Foam::radiation::radiationModel::New(Foam::Geometr icField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? #7 ? at ??:? #8 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #9 ? at ??:? Floating point exception (core dumped) |
Hi nadezhda, and welcome to the forum.
I need to clarify somethings - were you running the 3D tutorial case for fireFoam? What I understood (which may be incorrect) is that you took the 2D case, and replaced the files inside the "polyMesh" directory with those of the 3D case - in which case your solver will complain because variables were defined at specific boundaries. |
Versem, you are right. I checked boundaries and found couple very stupid mistakes (like a wrong gravity direction etc). Shame of me. Thank you :)
