Simo Sepponen
Rep Power: 10 ![]() |
I would like to calculate the mass of a phase as function of time using twoPhaseEulerFoam. Could this be done without modifying the solver, maybe with a function object? Is there a function object which integrates a variable over the domain? Thank you for your attention, Simo |
If the density of the phase is constant you can follow the volume fraction of the phase that you are interested in in the log of the solver. If you want to plot it you can use some bash to extract the values from the log. I typically use something like this: Code:
grep fra twoPhaseEulerFoam.log | awk '{print $5}' > volumeFraction Code:
alpha.particles volume fraction = 0.0005668175397 Min(alpha.particles) = 0 Max(alpha.particles) = 0.05349701286 awk also allows multiplication to have the entire mass using: Code:
awk '{print rho*$5*domainvolume}' If your density is not constant you maybe can use the volRegion functionObject to obtain a weighted volume average or a volume integral. Use the following to find some more information: Code:
find $FOAM_SRC -iname *volRegion* |
Display Modes | |
Divergence after change in mass flow rate in two phase flow | meetsunilkale | FLUENT | 1 | March 25, 2013 03:03 |
Discrete Phase & Mass Flow Rate | MagnusZeus | FLUENT | 0 | December 2, 2011 17:57 |
How to calculate mass flow of the discrete phase in Euler-lagrange model | juliom | CFX | 0 | November 8, 2011 19:50 |
Multiphase Multicomponent mass transfer -Initial condition | pannsave | CFX | 10 | February 9, 2011 01:12 |
liquid phase reactions and mass transfer | Swarup | FLUENT | 0 | January 17, 2005 00:47 |
