Cylinder
Old   August 15, 2016, 15:45
Default Cylinder
Alejandro
alejandrogra93 is on a distinguished road
Hello, I am student and I have to do a simulation about an impulsively started cylinder from the rest. However, I have some doubts about it. I have done a mesh of a cylinder contained in a rectangular mesh so I have 5 boundaries: left, right, top, bottom and cylinder. Moreover, I chose a dynamic mesh in order to have a moving cylinder. I must obtain two vortex behind the cylinder at low Reynolds. However, I obtain them above and below the cylinder, not behind of it. I don't know if the problem may be the boundary conditions. Could you help me, please? Thank you so much.
PD: The solver that I am using is pimpleDyMFoam.
alejandrogra93 is offline   Reply With Quote
Old   August 16, 2016, 08:12
Alejandro
Someone have a suggestion, please?
Old   August 28, 2016, 11:00
Catalina Valencia
CataV is on a distinguished road
Hello Alejandro
I'm working with a similar case too. I think that your problem may be related with the boundary conditions. You should attach the U file so I can take a look. Also I want to know if you're using sixDoFRigidBodyDisplacement, just because the constrains conditions can be forced the cylinder to rotate and the vortex shed in other directions
Best regards
CataV is offline   Reply With Quote
Flow past a 2D cylinder - High Re (1E+05) - Cd too high Pervispasco OpenFOAM Running, Solving & CFD 4 March 14, 2022 02:19
Drag force coefficient too high for a flow past a cylinder using komega sst Scabbard OpenFOAM Running, Solving & CFD 37 March 21, 2016 16:16
Forces Acting on a Rotating Cylinder (Moving Mesh) dreamchaser CFX 5 April 25, 2015 06:01
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 06:24
[blockMesh] Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 03:56
