a run time problem
Dear Foamers!
I have run a case with LTSinterFoam. and then wanted to continue it with interDymFoam, after mpirun I face the following error: would any one please help me with that? [4] --> FOAM FATAL ERROR: [4] request for volScalarField rDeltaT from objectRegistry region0 failed available objects of type volScalarField are 16 ( alpha.water_0 interfaceProperties:K nut alpha.water rho rAU k p_rgh nu gh nu1 p rho_0 nu2 alpha.air epsilon ) [4] [4] [4] From function objectRegistry::lookupObject<Type>(const word&) const [4] in file /home/openfoam/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 198. [4] FOAM parallel run aborting [4] [4] #0 Foam::error::printStack(Foam::Ostream&)[3] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [0] #1 Foam::error::abort() at ??:? [1] #1 Foam::error::abort() at ??:? at ??:? [3] #1 Foam::error::abort()[5] #1 Foam::error::abort() at ??:? [4] #1 Foam::error::abort() at ??:? [2] #1 Foam::error::abort() at ??:? [0] #2 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const at ??:? [1] #2 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const at ??:? [5] #2 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const at ??:? [3] #2 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const at ??:? [4] #2 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const at ??:? [0] #3 Foam::fv::localEulerDdtScheme<Foam::Vector<double> >::fvmDdt(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? at ??:? [1] #3 Foam::fv::localEulerDdtScheme<Foam::Vector<double> >::fvmDdt(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&)[5] #3 Foam::fv::localEulerDdtScheme<Foam::Vector<double> >::fvmDdt(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? at ??:? [2] #2 Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const& Foam::objectRegistry::lookupObject<Foam::Geometric Field<double, Foam::fvPatchField, Foam::volMesh> >(Foam::word const&) const[3] #3 Foam::fv::localEulerDdtScheme<Foam::Vector<double> >::fvmDdt(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? [4] #3 Foam::fv::localEulerDdtScheme<Foam::Vector<double> >::fvmDdt(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&) at ??:? [0] #4 at ??:? [2] #3 Foam::fv::localEulerDdtScheme<Foam::Vector<double> >::fvmDdt(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&)? at ??:? [3] #4 at ??:? [4] #4 at ??:? [1] #4 at ??:? [5] #4 ? at ??:? [0] #5 ?? at ??:? [2] #4 ? at ??:? ?[3] #5 at ??:? [1] #5 ? at ??:? [5] #5 ?? at ??:? [0] #6 __libc_start_main at ??:? [4] #5 at ??:? [2] #5 ?? in "/lib/x86_64-linux-gnu/libc.so.6" [0] #7 at ??:? [1] #6 __libc_start_main? at ??:? [3] #6 __libc_start_main at ??:? [5] #6 __libc_start_main at ??:? [4] #6 __libc_start_main? in "/lib/ at ??:? [2] #6 __libc_start_mainx86_64-linux-gnu/libc.so.6" [1] #7 in "/lib/x86_64-linux-gnu/libc.so.6" [5] #7 in "/lib/x86_64-linux-gnu/libc.so.6" [3] #7 in "/lib/x86_64-linux-gnu/libc.so.6" [4] #7 at ??:? -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- ??? in "/lib/x86_64-linux-gnu/libc.so.6" [2] #7 ?? at ??:? at ??:? at ??:? at ??:? at ??:? -------------------------------------------------------------------------- mpirun has exited due to process rank 0 with PID 3357 on node fatemeh-Lenovo-IdeaPad-P400-Touch exiting improperly. There are two reasons this could occur: 1. this process did not call "init" before exiting, but others in the job did. This can cause a job to hang indefinitely while it waits for all processes to call "init". By rule, if one process calls "init", then ALL processes must call "init" prior to termination. 2. this process called "init", but exited without calling "finalize". By rule, all processes that call "init" MUST call "finalize" prior to exiting or it will be considered an "abnormal termination" This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- [fatemeh-Lenovo-IdeaPad-P400-Touch:03356] 5 more processes have sent help message help-mpi-api.txt / mpi-abort [fatemeh-Lenovo-IdeaPad-P400-Touch:03356] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages |
