2D buoyantBoussinesqSimpleFoam weird solution |
August 29, 2016, 08:06 |
Rep Power: 9 |
Currently I am trying to simulate a simple HVAC case, an inlet in a room, vith 6 K deltaT. I used Pimple and simple solvers, but the problem is the same. I have two models, a 3D model and a 2D simplification. The 3D case works well, the solution is logical, as you can see in the first image (slice of the symmetry plane of the room,U magnitude). But, when I use the 2D case it isnīt (second image). I thought that adding more iterations was the solution but still have the same problem after 200.000 iterations. If anyone knows the solution, please tell me. Best regards, Daniel Last edited by danielbanos10; August 31, 2016 at 07:13. |
October 3, 2016, 10:45 |
Rep Power: 9 |
One of the solutions I found is using 3D with few cells in "y" direction and setting symmetryPlane BC.(pic attached).
Anyone had a similar problem ? |
October 4, 2016, 01:50 |
Rep Power: 20 |
It looks to as if your solution is not converged yet. Lower your tolerance in fvSolution and remove the relaxation in the temperature field. (h/e). Or raise them to 0.9 or something similar.
October 4, 2016, 02:00 |
#4 | |
Rep Power: 9 |
Weird solution output using version 3.2.7 | paulzhang | SU2 | 0 | April 13, 2016 04:56 |
Why 3D solid-pore geometry showing diverged solution? | Sargam05 | OpenFOAM | 0 | December 3, 2012 15:45 |
Analytic solution for 2D steady Euler equations | jojo81 | Main CFD Forum | 0 | October 15, 2012 12:05 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Discussion about Mesh independant solution | Seb | Main CFD Forum | 13 | May 22, 2001 13:37 |
