2D buoyantBoussinesqSimpleFoam weird solution
Old   August 29, 2016, 08:06
Default 2D buoyantBoussinesqSimpleFoam weird solution
danielbanos10's Avatar
danielbanos10 is on a distinguished road
Currently I am trying to simulate a simple HVAC case, an inlet in a room, vith 6 K deltaT. I used Pimple and simple solvers, but the problem is the same.
I have two models, a 3D model and a 2D simplification.
The 3D case works well, the solution is logical, as you can see in the first image (slice of the symmetry plane of the room,U magnitude). But, when I use the 2D case it isnīt (second image). I thought that adding more iterations was the solution but still have the same problem after 200.000 iterations.
If anyone knows the solution, please tell me.
Best regards,
Daniel
danielbanos10 is offline   Reply With Quote
Old   October 3, 2016, 10:45
One of the solutions I found is using 3D with few cells in "y" direction and setting symmetryPlane BC.(pic attached).
Anyone had a similar problem ?
Old   October 4, 2016, 01:50
Bloerb will become famous soon enough
It looks to as if your solution is not converged yet. Lower your tolerance in fvSolution and remove the relaxation in the temperature field. (h/e). Or raise them to 0.9 or something similar.
Bloerb is offline   Reply With Quote
Old   October 4, 2016, 02:00
Yes, that's was my first thought (reffering to the first post), so I changed the tolerance, did 200000 iterations, modified the relaxation of T to 0.8. And nothing changed... (in 2D case)
Weird solution output using version 3.2.7 paulzhang SU2 0 April 13, 2016 04:56
Why 3D solid-pore geometry showing diverged solution? Sargam05 OpenFOAM 0 December 3, 2012 15:45
Analytic solution for 2D steady Euler equations jojo81 Main CFD Forum 0 October 15, 2012 12:05
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Discussion about Mesh independant solution Seb Main CFD Forum 13 May 22, 2001 13:37
