August 31, 2016, 08:48 |
Solver if degree of turbulence is unkown
Rep Power: 9 |
Hello!
I am working on determining the degree of mass diffusion in a channel. I do not know the degree of turbulence that persists in the control volume. Which solver would you recommend if i have to find out turbulence at different time steps? I have tried using icofoam, but that gives me a steady state within a second after i start the simulation. Simplefoam seems to be too unsteady and the results make little sense. Help would be highly appreciated. Regards |
openfoam |
[SOWFA] pisoFoamTurbine solver contained in the SOWFA: SST Turbulence Model problems | capisedano | OpenFOAM Community Contributions | 2 | January 23, 2020 06:10 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 04:28 |
OpenCL linear solver for OpenFoam 1.7 (alpha) will come out very soon | qinmaple | OpenFOAM Announcements from Other Sources | 4 | August 10, 2012 11:00 |
Two equation turbulence models solver settings | truffaldino | FLUENT | 0 | March 5, 2011 20:49 |
