twoPhaseEulerFoam mixtureKEpsilon: zeroGradient for km/epsilonm at Walls???
Old   September 2, 2016, 05:51
Default twoPhaseEulerFoam mixtureKEpsilon: zeroGradient for km/epsilonm at Walls???
Kumar
kishpishar is on a distinguished road
In recent versions of twoPhaseEulerFoam (3.0 and beyond) the mixtureKEpsilon model is implemented which requires boundary files for km and epsilonm. In the corresponding tutorials (bubbleColumn) one notes strangely that:
zeroGradient BC has been used at walls for km and epsilonm whereas the respective wall functions have been used at walls for k.* and epsilon.*.
The tutorial runs, but is it correct to use zeroGradient for turbulence quantities at walls?
On the other hand, if I change zeroGradient to the respective wall functions, twoPhaseEulerFoam returns the
error:
--> FOAM FATAL ERROR:
request for turbulenceModel turbulenceProperties from objectRegistry region0 failed
available objects of type turbulenceModel are
2
turbulenceProperties.air
turbulenceProperties.water
Can anyone please let me know?
-Kumar
kishpishar is offline   Reply With Quote
twoPhaseEulerFoam bubble column crashes due to problems at outlet region hester OpenFOAM Running, Solving & CFD 5 July 21, 2024 08:19
Boundary Conditions MtnRunBeachBum OpenFOAM Pre-Processing 1 April 30, 2015 16:33
multiphaseEulerFoam loosing fluid with zeroGradient for p on walls??? petr.f. OpenFOAM Running, Solving & CFD 0 November 28, 2012 06:33
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 14:16
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 17:08
