September 15, 2016, 14:29 |
porousInterFoam
alberto
Rep Power: 10 |
within the installation from openfoam.org (openfoam 4) is the solver porousInterFoam there? i couldnt execute like doesnt exist, please any can help me.
September 16, 2016, 06:44 |
Rep Power: 9 |
go to opt/OpenFoam/tutorials and see if there is the solver you need. It is highly unlikely that if you have installed it properly, a solver would be missing.
open up your terminal and just write icoFoam. let me know what it says. |
September 19, 2016, 18:51 |
thanks for answer me
#3 | |
alberto
Rep Power: 10 |
i think so that i dont have it installed, because i cant found it in opt/OpenFoam/tutorials or solvers, would you explain me how to add it to the solver installation? this is what appears when i write icoFoam. root@dui-P45VA:/home/dui# icoFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.0-665f1db4c1f1 Exec : icoFoam Date : Sep 19 2016 Time : 17:45:51 Host : "dui-P45VA" PID : 4176 Case : /home/dui nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL IO ERROR: cannot find file file: /home/dui/system/controlDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 72. FOAM exiting |
September 19, 2016, 19:48 |
Hi Alberto,
It seems your OpenFOAM is installed, because the icoFoam worked. The tutorials are located on $FOAM_TUTORIALS directory, so see the content of this environment variable in the terminal: echo $FOAM_TUTORIALS The porousInterFoam is not present in the OF4. This solvers is deprecated since OF version 3.0 and now you can use the interFoam with baffles or adding a porous source through the fvOptions. Take a look on the tutorials/multiphase/interFoam/ras/damBreakPorousBaffle/ tutorial. Best regards, Jovani Obs.: Seems you are running OpenFOAM as root user (root@dui-P45VA:/home/dui#): this is really bad. It is better to run as a normal user, just a hint... |
September 19, 2016, 21:07 |
alberto
Rep Power: 10 |
thank u so much! i was trying to do a tutorial that i found in internet.
im starting to use OF, bucause in my thesis project i have to simulate a nitrogen flow in a pipe with a certain temperature distribution, whit a porous sample in the middle, and one part of the flow throught the sample and the other surrounds the sample. if you have any idea of what solver can help me or information, would be awesome. if its no tu much ask. |
Adding porosity to UEqn.H in porousInterFoam | jameswilson620 | OpenFOAM Programming & Development | 5 | November 25, 2016 22:19 |
Porosity and permeability in PorousInterFoam | jasouza1974 | OpenFOAM Pre-Processing | 14 | August 12, 2015 04:16 |
porousInterFoam vs interFoam | yanxiang | OpenFOAM Running, Solving & CFD | 8 | November 5, 2014 11:26 |
porousInterFoam | sachinlb | OpenFOAM Running, Solving & CFD | 0 | December 27, 2012 06:30 |
porousInterFoam | JF.JTT | OpenFOAM | 2 | May 1, 2011 14:05 |
