Home > Forums > OpenFOAM Running, Solving & CFD
How should I define a acceleration-terms.dat in FvOptions-tabulatedAccelerationSource
Old   October 24, 2016, 05:17
Default How should I define a acceleration-terms.dat in FvOptions-tabulatedAccelerationSource
金恒
jinheng is on a distinguished road
Sponsored Links
hi everyone, I want to define a time-change acceleration in sloshing movement. And maybe Fvoptions is a good way. Similar with tanksloshing3D6dof case in interDyMFoam. I want to define a acceleration term in non-inertial reference frame in interFoam. But I can not read the acceleration-term.dat using Fvoptions due to the formate of file.
So my question is :
1、Is there anywhere tell the formate of tabulatedaccelerationsource.
2、otherthan fvoptions, is there any good method to achieve non-inertial reference frame in interFoam. (I have try to added a "acc" just in the Uequ ,but the alpha.water does not change with "acc")
thanks very much for any advises or help.
Usage
Example usage:
\verbatim
SBM
type tabulatedAccelerationSource;
active yes;
tabulatedAccelerationSourceCoeffs
timeDataFileName "constant/acceleration-terms.dat";
\endverbatim
And I have attempted this thread in CFD-ONLINE(Time varying velocity inlet boundary conditions using TableFile.H). I use the same format of the tablefile. But it still give me the same errors:
1、Expected a '(' while reading Tuple2, found on line 2 the label 0
2、wrong token type - expected Scalar, found on line 2 the punctuation token '('
heng Jin
OUC
jinheng is offline   Reply With Quote
Sponsored Links
Thread Tools
Trackbacks are On
SR_Rate UDF For a MEMs model timjm Fluent UDF and Scheme Programming 0 February 22, 2013 11:53
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation on Windows, Mac and other Unsupported Platforms 129 June 19, 2010 09:23
How to define angular acceleration Randre Fluent UDF and Scheme Programming 0 April 20, 2010 13:21
HELP----Surface Reaction UDF Ashi Fluent UDF and Scheme Programming 0 May 25, 2009 09:39
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
Sponsored Links
