Home > Forums > OpenFOAM Running, Solving & CFD
Swak4Foam: problems with averaging a new field
Old   October 27, 2016, 07:22
Default Swak4Foam: problems with averaging a new field
Francesco Garita
fgarita is on a distinguished road
Hi everybody,
I am finding some problems with Swak4Foam. In particular, the situation is the following: I want to create a new field (called epsilon) by using an expressionField, which calls for UMean, produced by a fieldAverage; then I want to average this new field epsilon, but I get an error if I write epsilon within the fieldAverage.
What I managed to figure out is that the problem comes from the fact that OpenFOAM does not know how to initialize this new field (it only knows how to initialize UMean, pMean, etc.). The solutions I found are basically 2:
1) Do the following steps in sequence:
- Make a check to see whether UMean is present; if it is, then ask Swak4Foam to create the field epsilon;
- Let the solver run for some timestep (in order epsilon to be created);
- Include epsilon within the fieldAverage.
As you can see, this solution is very annoying because you have to wait that epsilon is created and then you have to include manually this new field within the fieldAverage. Furthermore, this will cause the total averaging time of epsilon to be shorter than the total averaging time of UMean, and this is definitely undesired.
2) Another option to solve the problem is the following:
- Make a second check to see whether epsilon is present; if it is, then ask Swak4Foam to make a second fieldAverage where only epsilon is present.
This solution works pretty well as epsilonMean is created for the first time when UMean is created for the first time, thus solving the problem of having two different total averaging times. Also, it does not require you to wait epsilon to be created in order to start averaging it. However, this solution has its own drawback represented by the fact that when a second fieldAverage is created, then the fieldAverageProperties file writes only the information related to the second field average. Somebody may think that if the information on UMean, pMean, etc. included in the fieldAverageProperties file are not present anymore, then the solver does not compute a correct average of UMean, pMean, etc. but I did make many checks and fortunately this seems not to be the case because, even though those information are not present anymore in the fieldAverageProperties file, OpenFOAM keeps those information in its registers anyway, therefore UMean, pMean, etc. should be calculated correctly in my opinion.
The reasons why I am writing this post are 2: first I would like somebody to confirm that UMean, pMean are indeed calculated correctly, and second I would be grateful if you could suggest me some more efficient way to do what I need to do, without losing the information on UMean, pMean, etc. present in the fieldAverageProperties file.
Thanks to anybody that will reply to this post.
Francesco
P.S. If you wish, you can go through the functions I included in my ControlDict in the second case:
functions
    fieldAverage1
            type            fieldAverage;
            functionObjectLibs ( "libfieldFunctionObjects.so" );
            enabled         true;
            outputControl   outputTime;
            fields
                U
                    mean        on;
                    prime2Mean  on;
                    base        time;
                p
                    mean        on;
                    prime2Mean  on;
                    base        time;
    UMeanCheck
            type executeIfObjectExists;
            objectName UMean;
            checkType true;
            objectType volVectorField;
            objectShouldExist true;
            readDuringConstruction false;
            functions {
                doCalc  {
                             type expressionField;
                             fieldName "epsilon";
                             expression "nu*(grad(U) && grad(U))-2*nu*(grad(UMean) && grad(U))+nu*(grad(UMean) && grad(UMean))";
                             autowrite true;
                             outputControlMode timeStep;
                             outputInterval 1;
    epsilonCheck
            objectName epsilon;
            checkType true;
            objectType volScalarField;
            functions {
                    doCalc{
                            type            fieldAverage;
                            enabled         true;
                            fields
                                epsilon
                                    mean        on;
                                    prime2Mean  off;
                                    base        time;
fgarita is offline   Reply With Quote
Old   October 28, 2016, 03:27
floquation's Avatar
Kevin van As
floquation will become famous soon enough
I don't know the answer, but I have two quick suggestions that you might like to try:
  1. At some point in time, I decided that I need the following function as very first in everything I do. I'm not sure why anymore, but it had to do with things not being initialized when I needed them, which seems related to your problem. Then again, if I Google, it seems related to the mesh. Try it anyway:
    functions
        doInit {
            type initSwakFunctionObject;
  2. Perhaps the "executeIfStartTime" FO might be useful. Whenever I need to "get a calculation started", I use this to set initial values to global variables, as in the following snippet. I reckon it may very well be used to initialize your fields as well.
    I'll copy a full example of what I have used in one case:
    initPosStarter{
        type executeIfStartTime;
        outputInterval 1;
        readDuringConstruction false; // Must be false for "executeIfStartTime"-FO
        runIfStartTime yes;
        functions {
            setStartTime
                type calculateGlobalVariables;
                valueType internalField;
                toGlobalNamespace globals;
                toGlobalVariables ( startTime );
                variables ( "startTime=time();" );
                noReset true; // Maintain this variable forever
            calcInitPos
              valueType surface;
              surfaceName interface;
              surface
                type isoSurfaceCell;
                isoField alpha1;
                isoValue 0.5;
                interpolate false;
                regularise false; // do not simplify
              toGlobalNamespace interface; //write to this one
              toGlobalVariables (
                position0
                position
              variables (
                "position=average(pos());"
                "position0=position;"
Good luck!
floquation is offline   Reply With Quote
Thread Tools
Trackbacks are On
New Solver error Foam::error::printStack upuli OpenFOAM Running, Solving & CFD 3 November 13, 2016 20:45
Having problems getting the mean vorticity field from mean velocity field Martin1 Fluent UDF and Scheme Programming 1 June 18, 2015 08:20
Averaging along an axis.. swak4foam? tiam OpenFOAM Programming & Development 7 October 7, 2014 17:30
CyclicAMI: Problems with pressure field Thoma OpenFOAM Running, Solving & CFD 13 June 28, 2014 08:34
Averaging field over a spatial direction fs82 OpenFOAM 10 August 12, 2009 10:44
