Error during tutorial 2.1.5.3 Mapfields
Old   November 8, 2016, 10:23
Default Error during tutorial 2.1.5.3 Mapfields
Roy
mazamitla is on a distinguished road
Hey everybody,
I just started using openFOAM and am working my way through the tutorial. So far I encountered a few problems which I eventually was able to fix myself with a little search here and there.
However during step 2.1.5.3 of the tutorial I am now stuck.
I created a new folder cavityFine in the workingDir using as in 2.1.5.1 of the tuturial:
mkdir cavityFine
cp -r cavity/constant cavityFine
cp -r cavity/system cavityFine
cd cavityFine
Then I edited the blockMeshDict file as described in step 2.1.5.2 of the tutorial, subsequently ran blockMesh (this works).
However during step 2.1.5.3 when I execute the command:
mapFields ../cavity -consistent
The utility should run with output to the terminal including:
Source: ”..” ”cavity”
Target: ”.” ”cavityFine”
Create databases as time
Source time: 0.5
Target time: 0.5
Create meshes
Source mesh size: 400 Target mesh size: 1600
Consistently creating and mapping fields for time 0.5
interpolating p
interpolating U
End
This is supposed to be the result as stated in the tutorial however I get the following outcome:
--> FOAM FATAL IO ERROR:
cannot find file
file: ./cavity/system/controlDict at line 0.
From function regI0object::readStream()
in file db/regI0object/regI0objectRead.C at line 237.
FOAM exiting
I am not sure how to proceed and would appreciate any help advise that you could provide to tackle this problem.
Regards,
mazamitla is offline   Reply With Quote
Old   November 8, 2016, 12:17
Arsalan
arsalan.dryi is on a distinguished road
Hi Roy,
Problem is explained obviously in the error text, just read it.
Check if the controlDict is exist at cavity/system.
Regards,
Arsalan.
arsalan.dryi is offline   Reply With Quote
Old   November 9, 2016, 08:47
Roy
Hey arsalan,
Thanks for the advice, I checked the folder cavity/system and there is definately a "controlDict" file present there. See image below.
Any other suggestions? Maybe I am missing something very simple.
Old   November 9, 2016, 13:12
Mahdi Hosseinali
anishtain4 is on a distinguished road
Are you sure you are in the right directory?
It should read:
Target: ”<path>” ”cavityFine”
but in the attached picture it says:
source "." "cavity"
Note the single and double dots on the first line. You should be in cavityFine when running the mapFields utility. Also both cases should be in the same directory for .. to be able to address the cavity case
anishtain4 is offline   Reply With Quote
cavity, cavityfine, error, mapfields, tutorial
tutorial files KITetima FLUENT 8 November 23, 2019 16:05
AMI - Propeller Tutorial diverging kingmaker OpenFOAM Running, Solving & CFD 2 November 4, 2016 02:57
STAR-CD Tutorial shekhar aryal STAR-CD 4 March 22, 2010 03:25
CFD-ACE Tutorial for Serpentine Fuel cell Channel Taqi Main CFD Forum 0 April 13, 2008 13:12
Rotor/stator tutorial, and how to... gilberto CFX 5 January 21, 2002 09:41
