[swak4Foam] Problem with triSurface.so and swak4Foam
Old   November 16, 2016, 11:36
Default Problem with triSurface.so and swak4Foam
PieterjanR is on a distinguished road
Hi all
I am using OpenFoam extend 3.2. The first time I noted that something was wrong with my OpenFoam installation was this error message from running a test case:
--> FOAM Warning :
    From function dlLibraryTable::open(const fileName& functionLibName)
    in file db/dlLibraryTable/dlLibraryTable.C at line 124
    could not load libtriSurface.so: cannot open shared object file: No such file or directory
I traced this back to an error during the installation of swak4Foam:
Swak version is 0.4.0
Bison is version 2.7.12-4996
Flex is version 2.5.35 (Minor version: 35)
OpenFOAM-version: Major 3 Minor 2 Patch 0 (-1 == x / 0) Fork: extend
Making dependency list for source file ExpressionResult/DelayedExpressionResult.C
could not open file string.H for source file helpers/exprString.C
The files string.H and time.H have apparently moved compared to the previous OpenFoam version? I thought this was related to this thread:
https://sourceforge.net/p/openfoam-e...ndrelease/281/
Even after updating the swak4foam version to 0.4.0, or git static checking to the original commit
https://github.com/Unofficial-Extend...6b8810e1afa4ee,
still no luck. The error persists.
According to
http://www.cfd-online.com/Forums/ope...risurface.html
this is because triSurface.so is moved to meshTools? The solution proposed there, creating a symbolic link in the $FOAM_SRC folder doesn't seem to work for me.
Anyone came across this before and has a solution?
Thanks in advance!
PieterjanR is offline   Reply With Quote
Old   November 20, 2016, 12:51
Retired Super Moderator
Bruno Santos
Greetings PieterjanR,
There is something very strange going on with your installation, because I've re-tested just now with foam-extend 3.2 (the official name and version of this fork) and with swak4Foam 0.4.0 and I had absolutely no problems building it.
Hold on...
--> FOAM Warning :
No no no... that message "could not open file" when building is explained here: http://openfoamwiki.net/index.php/In...e_or_directory - essentially it can be ignored, since that is not the problem.
The message about not being able to load "libtriSurface.so" is not a problem with swak4Foam, it's because foam-extend 3.2 itself no longer has that library.
The solution is to simply remove "libtriSurface.so" from the "libs" list in "system/controlDict".
Best regards,
Bruno
edit: Moved thread from the installation sub-forum to the run and solving sub-forum.
Old   November 21, 2016, 09:54
Hi Bruno
Indeed, this was surprisingly simple
I'll try to run a clean install of swak4foam and see if the error is gone now.
openfoam, swak4foam, trisurface
[swak4Foam] swak4foam >>>> INSTALLATION PROBLEM steven123 OpenFOAM Community Contributions 35 January 11, 2021 16:53
[swak4Foam] Problem to calculate grad(U) using swak4Foam Hugoles OpenFOAM Community Contributions 12 November 24, 2020 10:28
[swak4Foam] [OpenFOAM plus] [v1612+] swak4Foam installation problem in Windows (Allwmake) LThomes OpenFOAM Community Contributions 7 October 6, 2020 13:36
[swak4Foam] Problem with swak4Foam and OpenFOAM 2.3.1 behzad-cfd OpenFOAM Community Contributions 4 March 25, 2017 16:19
[swak4Foam] foam-extend-3.2 installing problem: swak4Foam failed to install due to Bison lxwd OpenFOAM Community Contributions 1 March 20, 2016 16:03
