November 23, 2016, 17:42 |
Initial and Final Residual Null
Rep Power: 10 |
Hi to all,
i'm working on my own adjoint solvers. I compiled correctly the solver, which solves only the the adjoint equations. I first run the direct problem and then i put the U and p folders into the 0 folder of my adjoint case and then i run the adjoint simulation. These are the results Code:
Time = 1e-05 smoothSolver: Solving for Uax, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Uay, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Uaz, Initial residual = 0, Final residual = 0, No Iterations 0 GAMG: Solving for pa, Initial residual = 0, Final residual = 0, No Iterations 0 Adjoint continuity errors : sum local = 0, global = 0, cumulative = 0 Thanks for help |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 06:37 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
