fsch1 |
November 30, 2016 08:26 |
usage of kinematicSingleLayer
i have some troubles using the kinematicSingleLayer.
The basis for my simulation is the hot-box tutorial. But I don't need the thermal results, just the wallFilm. For simplification I want to change the surfaceFilmModel from thermoSingleLayer to kinematicSingleLayer.
In the reactingCloud1Properties I still have this line:
surfaceFilmModel thermoSurfaceFilm;
and in the surfaceFilmProperties i made this change:
surfaceFilmModel kinematicSingleLayer; // thermoSingleLayer;
regionName wallFilmRegion;
active true;
kinematicSingleLayerCoeffs
filmThermoModel constant;
constantCoeffs
specie water;
rho0 1000;
mu0 1e-3;
sigma0 0.07;
the liquidCoeffs I copied from the rivulet-tutorial.
But now, when I run the reactingParcelFilmFoam I get
Constructing surface film model
Selecting surfaceFilmModel kinematicSingleLayer
Selecting region model functions
none
Selecting filmThermoModel constant
Selecting film injection models
none
Selecting filmTurbulenceModel laminar
Selecting film force models
contactAngle
Selecting distribution model normal
thermocapillary
No finite volume options present
Courant Number mean: 0.003975948189 max: 0.01690175586
Starting time loop
Courant Number mean: 0.003975550634 max: 0.01690006585
Film max Courant number: 0
deltaT = 1.439677512e-05
Time = 1.43968e-05
Solving 3-D cloud reactingCloud1
--> FOAM FATAL ERROR:
Ts field not available for kinematicSingleLayer
From function virtual const volScalarField& Foam::regionModels::surfaceFilmModels::kinematicSingleLayer::Ts() const
in file kinematicSingleLayer/kinematicSingleLayer.C at line 1012.
FOAM aborting
#0 Foam::error::printStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::regionModels::surfaceFilmModels::kinematicSingleLayer::Ts() const at ??:?
#3 Foam::ThermoSurfaceFilm<Foam::KinematicCloud<Foam::Cloud<Foam::ReactingParcel<Foam::ThermoParcel<Foam::KinematicParcel<Foam::particle> > > > > >::cacheFilmFields(int, int, Foam::regionModels::surfaceFilmModels::surfaceFilmModel const&) at ??:?
#4 ? at ??:?
#5 ? at ??:?
#6 ? at ??:?
#7 ? at ??:?
#8 ? at ??:?
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#10 ? at ??:?
Abort
where do I have to define the Ts? As I understand, its the temperature on the surface of the wall.
