cfd@kgp |
December 9, 2016 07:20 |
creating a new/derived field and writing at output time
Dear Foamers',
I want to create a new/derived field and write it at the output time.
lets visualize a new volScalarField of mag(U).
I found out there three ways to do it---
1. edit the application (I want to omit this option)
2. using Swak4foam with expressionField. I tried it by editing the controlDict
velocityMagSquared
type expressionField;
//outputControl outputTime;
//outputInterval 1;
fieldName UMag2;
expression "U&U";
autowrite true;
I also get the output file written in the corresponding output/time directory.
But problem is paraview do not import thes new field, it do not have this information.
the last way is using coded function/dynamic code,
I tried this, by adding the following lines in controlDict
compute_ptot
functionObjectLibs ( "libutilityFunctionObjects.so" );
type coded;
enabled true;
redirectType ptot;
// outputControl outputTime;
// outputInterval 1;
code
const volVectorField& U = mesh().lookupObject<volVectorField>("U");
volScalarField ptot
IOobject
"ptot",
mesh().time().timeName(),
U.mesh(),
IOobject::NO_READ,
IOobject::AUTO_WRITE
mag(U)
I neither get any new file in the corresponding output/time directory nor any visualization..:confused::confused::confused:
Please give me some suggesions with option 2 or 3.
I am trying this in OF 3.x and using following libraries,
libs (
"libOpenFOAM.so"
"libsimpleSwakFunctionObjects.so"
"libswakFunctionObjects.so"
"libgroovyBC.so"
"mylibfvOptions.so"
Thanks,
